The Tele-MAGMaS: An Aerial-Ground Comanipulator System - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Robotics and Automation Magazine Année : 2018
The manipulation of large objects by robotic systems is a challenge for applications in the construction industry, industrial decommissioning, and urban search and rescue (USAR). These are associated with dangerous environments and thus motivate devising robotic solutions to replace human presence. Furthermore, they often require manipulation of long objects, such as pipes, bars, beams, and metal frameworks, with limited access to their center of mass (CoM).
2018_ieeeram_staub.pdf (2.75 Mo) Télécharger le fichier
hal-01935127 , version 1 (26-11-2018)
Nicolas Staub, Mostafa Mohammadi, Davide Bicego, Quentin Delamare, Hyunsoo Yang, et al.. The Tele-MAGMaS: An Aerial-Ground Comanipulator System. IEEE Robotics and Automation Magazine, 2018, 25 (4), pp.66-75. ⟨10.1109/MRA.2018.2871344⟩. ⟨hal-01935127⟩
196 Consultations
319 Téléchargements
