, Probabilistic robotics, 2005.
Belief space planning simplified: Trajectory-optimized lqg (t-lqg), 2016. ,
Rapidly-exploring random belief trees for motion planning under uncertainty, ICRA'11, pp.723-730, 2011. ,
Planning with uncertainty in position an optimal and efficient planner, IROS'05, pp.2435-2442, 2005. ,
Perception-aware path planning, 2016. ,
C-opt: Coverage-aware trajectory optimization under uncertainty, IEEE Robotics and Automation Letters, vol.1, issue.2, pp.1020-1027, 2016. ,
Motion planning under uncertainty using differential dynamic programming in belief space, Robotics Research, pp.473-490, 2017. ,
Observabilityaware trajectory optimization for self-calibration with application to uavs, IEEE Robotics and Automation Letters, vol.2, issue.3, pp.1770-1777, 2017. ,
Reliable robust path planning with application to mobile robots, International Journal of Applied Mathematics and Computer Science, vol.19, issue.3, pp.413-424, 2009. ,
Search-based motion planning for quadrotors using linear quadratic minimum time control, IROS'17, pp.2872-2879, 2017. ,
Search-based Motion Planning for, Aggressive Flight in SE, issue.3, 2017. ,
Flat-rrt*: A sampling-based optimal trajectory planner for differentially flat vehicles with constrained dynamics, IFAC-PapersOnLine, vol.50, issue.1, pp.6965-6970, 2017. ,
Incremental micro-uav motion replanning for exploring unknown environments, ICRA'13, pp.2452-2458, 2013. ,
Vision-based reactive planning for aggressive target tracking while avoiding collisions and occlusions, IEEE Robotics and Automation Letters, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01836586
Flatness and defect of nonlinear systems: Introductory theory and examples, International J. of Control, vol.61, issue.6, pp.1327-1361, 1995. ,
Differential flatness of quadrotor dynamics subject to rotor drag for accurate tracking of highspeed trajectories, IEEE Robotics and Automation Letters, vol.3, issue.2, pp.620-626, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01658577
Derivative-free kalman filtering for autonomous navigation of unmanned ground vehicles, ICSCS'12, pp.1-6, 2012. ,
A computationally efficient motion primitive for quadrocopter trajectory generation, IEEE Transactions on Robotics, vol.31, issue.6, pp.1294-1310, 2015. ,
Polynomial trajectory planning for aggressive quadrotor flight in dense indoor environments, Robotics Research, pp.649-666, 2016. ,
B-spline parameterized optimal motion trajectories for robotic systems with guaranteed constraint satisfaction, Mechanical Sciences, vol.6, issue.2, p.163, 2015. ,
qpOASES: A parametric active-set algorithm for quadratic programming, Mathematical Programming Computation, vol.6, issue.4, pp.327-363, 2014. ,
Geometric tracking control of a quadrotor UAV on SE(3), 49th IEEE Conf. on Decision and Control, pp.5420-5425, 2010. ,
Visp for visual servoing: a generic software platform with a wide class of robot control skills, IEEE Robotics and Automation Magazine, vol.12, issue.4, pp.40-52, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00351899
The TeleKyb Framework for a Modular and Extendible ROS-based Quadrotor Control, ECMR'13, pp.19-25, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00908803
Contributions to optimal and reactive vision-based trajectory generation for a quadrotor uav, Ph.D. dissertation, Université Rennes, vol.1, 2018. ,
URL : https://hal.archives-ouvertes.fr/tel-01972349
