Mean Field Analysis of Personalized PageRank with Implications for Local Graph Clustering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Statistical Physics Année : 2018
We analyse a mean-field model of Personalized PageRank on the Erdos-Renyi random graph containing a denser planted Erdos-Renyi subgraph. We investigate the regimes where the values of Personalized PageRank concentrate around the mean-field value. We also study the optimization of the damping factor, the only parameter in Personalized PageRank. Our theoretical results help to understand the applicability of Personalized PageRank and its limitations for local graph clustering.
MeanFieldPPR_arxiv.pdf (431.08 Ko) Télécharger le fichier
hal-01936016 , version 1 (27-11-2018)
Konstantin Avrachenkov, Arun Kadavankandy, Nelly Litvak. Mean Field Analysis of Personalized PageRank with Implications for Local Graph Clustering. Journal of Statistical Physics, 2018, 173 (3-4), pp.895 - 916. ⟨10.1007/s10955-018-2099-5⟩. ⟨hal-01936016⟩
109 Consultations
295 Téléchargements
