Swept volume parametrization for isogeometric analysis, The Mathematics of Surfaces (MoS XIII 2009), vol.5654, pp.19-44, 2009. ,
DOI : 10.1007/978-3-642-03596-8_2
URL : http://www.ag.jku.at/pubs/2009ahjpsv.pdf
A trivariate Clough-Tocher scheme for tetrahedral data, Computer Aided Geometric Design, vol.1, pp.169-181, 1984. ,
Construction of Bézier points of quadrilaterals from Bézier triangles, Computer-Aided Design, vol.12, pp.21-24, 1980. ,
Volumetric parametrization from a level set boundary representation with PHT-splines, Computer-Aided Design, vol.82, pp.29-41, 2017. ,
Functional composition algorithms via blossoming, ACM Transactions on Graphics, vol.12, pp.113-135, 1993. ,
Compositing Bézier simplexes, ACM transactions on Graphics, vol.7, pp.198-221, 1998. ,
Isogeometric unstructured tetrahedral and mixed-element Bernstein-Bézier discretizations, Computer Methods in Applied Mechanics and Engineering, vol.319, pp.83-123, 2017. ,
A new approach to solid modeling with trivariate T-spline based on mesh optimization, Computer Methods in Applied Mechanics and Engineering, vol.200, pp.3210-3222, 2011. ,
Conversion from Bézier rectangles to Bézier triangles, Computer-Aided Design, vol.19, issue.1, pp.25-28, 1987. ,
Matched G k-constructions always yield C k-continuous isogeometric elements, Computer Aided Geometric Design, vol.34, pp.67-72, 2015. ,
Local lagrange interpolation with cubic C 1 splines on tetrahedral partitions, Journal of Approximation Theory, vol.160, pp.89-102, 2009. ,
Conversion of a triangular Bézier patch into three rectangular Bézier patches, Computer Aided Geometric Design, vol.13, pp.219-226, 1996. ,
Conversion between triangular and rectangular Bézier patches, Computer Aided Geometric Design, vol.18, pp.667-671, 2001. ,
Isogeometric analysis: CAD, finite elements, NURBS, exact geometry, and mesh refinement, Computer Methods in Applied Mechanics and Engineering, vol.194, pp.4135-4195, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-01513346
Isogeometric analysis on triangulations, Computer-Aided Design, vol.46, pp.45-57, 2014. ,
A C r trivariate macro-element based on the Alfeld split of tetrahedra, Journal of Approximation Theory, vol.175, pp.114-131, 2013. ,
Volumetric T-Spline construction using Boolean operations, Engineering with Computers, vol.30, issue.4, pp.425-439, 2014. ,
An optimal algorithm for expanding the composition of polynomials, ACM Transaction on Graphics, vol.16, pp.155-178, 1997. ,
Volumetric parameterization and trivariate B-spline fitting using harmonic functions, Computer Aided Geometric Design, vol.26, pp.648-664, 2009. ,
Dimension and bases for geometrically continuous splines on surfaces of arbitrary topology, Computer Aided Geometric Design, vol.45, pp.108-133, 2016. ,
Isogeometric analysis suitable trivariate NURBS representation of composite panels with a new offset algorithm, Computer-Aided Design, vol.55, pp.49-63, 2014. ,
Spline volume fairing, Lecture Notes in Computer Science, vol.6920, pp.553-561, 2012. ,
A C 1 quadratic trivariate macro-element space defined over arbitrary tetrahedral partitions, Journal of Approximation Theory, vol.158, pp.126-142, 2009. ,
Multivariate normalized Powell-Sabin B-splines and quasi-interpolants, Computer Aided Geometric Design, vol.30, pp.2-19, 2013. ,
Optimizing domain parameterization in isogeometric analysis based on Powell-Sabin splines, Journal of Computational and Applied Mathematics, vol.289, pp.68-86, 2015. ,
Trivariate solid T-spline construction from boundary triangulations with arbitrary genus topology, Computer-Aided Design, vol.45, pp.351-360, 2013. ,
An optimization approach for constructing trivariate B-spline solids, Computer-Aided Design, vol.46, pp.179-191, 2014. ,
Isogeometric analysis with Bézier tetrahedra, Computer Methods in Applied Mechanics and Engineering, vol.316, pp.782-816, 2017. ,
Parameterization of computational domain in isogeometric analysis: methods and comparison, Computer Methods in Applied Mechanics and Engineering, vol.200, pp.2021-2031, 2011. ,
Constructing IGA-suitable planar parameterization from complex CAD boundary by domain partition and global/local optimization, Computer Methods in Applied Mechanics and Engineering, vol.328, pp.175-200, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01599319
Isogeometric computation reuse method for complex objects with topology-consistent volumetric parameterization, Computer-Aided Design, vol.91, pp.1-13, 2017. ,
Optimal analysis-aware parameterization of computational domain in 3D isogeometric analysis, Computer-Aided Design, vol.45, pp.812-821, 2013. ,
URL : https://hal.archives-ouvertes.fr/inria-00539616
Analysis-suitable volume parameterization of multi-block computational domain in isogeometric applications, Computer-Aided Design, vol.45, pp.395-404, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00685002
Constructing analysis-suitable parameterization of computational domain from CAD boundary by variational harmonic method, Journal of Computational Physics, vol.252, pp.275-289, 2013. ,
URL : https://hal.archives-ouvertes.fr/inria-00585663
High-quality construction of analysis-suitable trivariate NURBS solids by reparameterization methods, Computational Mechanics, vol.54, pp.1303-1313, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00922544
Solid T-spline construction from boundary representations for genus-zero geometry, Computer Methods in Applied Mechanics and Engineering, vol.201, pp.185-197, 2012. ,
Conformal solid T-spline construction from boundary T-spline representations, Computational Mechanics, vol.51, pp.1051-1059, 2013. ,
