A modeling approach for addressing power supply switching noise related failures of integrated circuits, DATE, vol.2, pp.1078-1083, 2004. ,
Impact of power-supply noise on timing in high-frequency microprocessors, IEEE ADVP, vol.27, issue.1, pp.135-144, 2004. ,
Dynamic variation monitor for measuring the impact of voltage droops on microprocessor clock frequency, CICC, pp.1-4, 2010. ,
Adaptive frequency and biasing techniques for tolerance to dynamic temperature-voltage variations and aging, ISCC, pp.292-604, 2007. ,
Parameter variations and impact on circuits and microarchitecture, DAC, pp.338-342, 2003. ,
Next generation intel core micro-architecture (nehalem) clocking, IEEE SSC, vol.44, issue.4, pp.1121-1129, 2009. ,
Circuit design and modeling techniques for enhancing the clock-data compensation effect under resonant supply noise, IEEE SSC, vol.45, issue.10, pp.2130-2141, 2010. ,
On-die droop detector for analog sensing of power supply noise, IEEE SSC, vol.39, issue.4, pp.651-660, 2004. ,
A fullyautomated desynchronization flow for synchronous circuits, DAC, pp.982-985, 2007. ,
Elastic circuits, IEEE CAD, vol.28, issue.10, pp.1437-1455, 2009. ,
Ring oscillator clocks and margins, Asynchronous Circuits and Systems (ASYNC), pp.19-26, 2016. ,
A 90nm variable frequency clock system for a power-managed itanium architecture processor, IEEE SSC, vol.41, issue.1, pp.218-228, 2006. ,
Active management of timing guardband to save energy in POWER7, MICRO-44, pp.1-11, 2011. ,
A 22 nm all-digital dynamically adaptive clock distribution for supply voltage droop tolerance, IEEE SSC, vol.48, issue.4, pp.907-916, 2013. ,
Steamroller module and adaptive clocking system in 28 nm cmos, IEEE Journal of Solid-State Circuits, vol.50, issue.1, pp.24-34, 2015. ,
Metastability-containing circuits, IEEE Transactions on Computers, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01936292
Synchronization circuit performance, IEEE SSC, vol.37, issue.2, pp.202-209, 2002. ,
Synchronization and arbitration in digital systems, 2008. ,
