Graphlet Count Estimation via Convolutional Neural Networks
Graphlets are defined as k-node connected induced subgraph patterns. For instance, for an undirected graph,
3-node graphlets include close triangle and open triangle. The number of each graphlet, called graphlet count,
is a signature which characterizes the local network structure of a given graph. Graphlet count plays a prominent
role in network analysis of many fields, most notably bioinformatics and social science. However, computing
exact graphlet count is inherently difficult and computational expensive because the number of graphlets grows
exponentially large as the graph size and/or graphlet size grow. To deal with this difficulty, many sampling methods
were proposed to estimate graphlet count with bounded error. Nevertheless, these methods require large number
of samples to be statistically reliable, which is still computationally demanding. Intuitively, learning from historic graphs can make estimation more accurate and avoid many repetitive counting to reduce computational cost. Based on this idea, we propose a convolutional neural network (CNN) framework and two preprocessing techniques to estimate graphlet count. Extensive experiments on two types of random graphs and real world biochemistry graphs show that our framework can offer substantial speedup on estimating graphlet count of new graphs with high accuracy.
