Rotting bandits are not harder than stochastic ones - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In bandits, arms' distributions are stationary. This is often violated in practice, where rewards change over time. In applications as recommendation systems, online advertising, and crowdsourcing, the changes may be triggered by the pulls, so that the arms' rewards change as a function of the number of pulls. In this paper, we consider the specific case of non-parametric rotting bandits, where the expected reward of an arm may decrease every time it is pulled. We introduce the filtering on expanding window average (FEWA) algorithm that at each round constructs moving averages of increasing windows to identify arms that are more likely to return high rewards when pulled once more. We prove that, without any knowledge on the decreasing behavior of the arms, FEWA achieves similar anytime problem-dependent, O(log(KT)), and problem-independent, O(sqrtKT), regret bounds of near-optimal stochastic algorithms as UCB1 of Auer et al. (2002a). This result substantially improves the prior result of Levine et al. (2017) which needed knowledge of the horizon and decaying parameters to achieve problem-independent bound of only O(K1/3T2/3). Finally, we report simulations confirming the theoretical improvements of FEWA.
seznec2019rotting_arxiv.pdf (1.37 Mo) Télécharger le fichier
hal-01936894 , version 1 (27-11-2018)
hal-01936894 , version 2 (09-05-2020)
  • HAL Id : hal-01936894 , version 1
Julien Seznec, Andrea Locatelli, Alexandra Carpentier, Alessandro Lazaric, Michal Valko. Rotting bandits are not harder than stochastic ones. International Conference on Artificial Intelligence and Statistics, 2019, Naha, Japan. ⟨hal-01936894v1⟩
219 Consultations
214 Téléchargements
