Hardware topology management in MPI applications through hierarchical communicators - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Parallel Computing Année : 2018
The MPI standard is a major contribution in the landscape of parallel programming. Since its inception in the mid 90s it has ensured portability and performance for parallel applications on a wide spectrum of machines and architectures. With the advent of multicore machines, understanding and taking into account the underlying physical topology and memory hierarchy have become of paramount importance. On the other hand, providing abstract mechanisms to manipulate the hardware topology is also fundamental. The MPI standard in its current state, however, and despite recent evolutions is still unable to offer mechanisms to achieve this. In this paper, we detail several additions to the standard for building new MPI communicators corresponding to hardware hierarchy levels. It provides the user with tools to address hardware topology and locality issues while improving application performance.
HAL.pdf (10.28 Mo) Télécharger le fichier
hal-01937123 , version 1 (27-11-2018)
hal-01937123 , version 2 (28-11-2018)
Brice Goglin, Emmanuel Jeannot, Farouk Mansouri, Guillaume Mercier. Hardware topology management in MPI applications through hierarchical communicators. Parallel Computing, 2018, 76, pp.70 - 90. ⟨10.1016/j.parco.2018.05.006⟩. ⟨hal-01937123v2⟩
117 Consultations
170 Téléchargements
