Dispersive and dispersive-like bores in channels with sloping banks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2018
In this paper, a detailed analysis of undular bore dynamics in channels of variable cross-section is presented. Two undular bore regimes, Low Froude Number (LFN) and High Froude Number (HFN), are simulated with a Serre-Green-Naghdi model, and the results are compared with the experiments by Treske. We show that contrary to Favre waves and HFN bores, which are controlled by dispersive non-hydrostatic mechanisms, LFN bores correspond to a hydrostatic phenomenon. The dispersive-like properties of the LFN bores is related to wave refraction on the banks in a way similar to that of edge waves in the nearshore. A fully hydrostatic theoretical model allowing to describe these dispersive-like bores is derived and compared to the observations, confirming our claim.
Dans cet article, une analyse dille la dynamique des ressauts undulaires dans des canaux de section variable est prnt Desrmes Low Froude Number (LFN) et High Froude Number (HFN), sont simulvec un mod Serre-Green-Naghdi et les rltats sont comparux expences de Treske. Nous montrons que, contrairement aux ondes Favre et aux ondes HFN, contrlar des mnismes dispersifs non hydrostatiques, les ondes LFN correspondent phm hydrostatique. Les propris de dispersion des ressauts LFN sont li raction des vagues sur les berges, de la m mani que les edge waves. Un mod thique hydrostatique permettant de dire ces ondes \dispersive-like" est dv comparx observations, confirmant ainsi notre hypoth.
RR9228 (1).pdf (3.15 Mo) Télécharger le fichier
hal-01938547 , version 1 (28-11-2018)
hal-01938547 , version 2 (30-11-2018)
  • HAL Id : hal-01938547 , version 2
Rémi Chassagne, Andrea Gilberto Filippini, Mario Ricchiuto, Philippe Bonneton. Dispersive and dispersive-like bores in channels with sloping banks. [Research Report] RR-9228, Inria Bordeaux Sud-Ouest. 2018. ⟨hal-01938547v2⟩
162 Consultations
312 Téléchargements
