Upwind methods for hyperbolic conservation laws with source terms, Comput. Fluids, vol.235, issue.8, pp.1049-1071, 1994. ,
Flux di?erence splitting and the balancing of source terms and flux gradients, J. Comput. Phys, vol.165, pp.89-125, 2000. ,
Godunov-type methods for free surface shallow water flows: a review, J.Hydraul.Res, vol.45, p.746, 2007. ,
Central schemes for balance laws, Hyperbolic Problems: Theory, Numerics, Applications, vol.141, pp.821-829, 2001. ,
Central-upwind schemes for the Saint-Venant system, ESAIM: M2AN, vol.36, pp.397-425, 2002. ,
A second-order well-balanced positivity preserving central-upwind scheme for the Saint-Venant system, Commun. Math. Sci, vol.5, pp.133-160, 2007. ,
Mathemathical balancing of flux gradient and source terms prior to using roe's approximate riemann solver, J.Comput.Phys, vol.192, pp.422-451, 2003. ,
Adaptive quadtree simulation of shallow flows with wet-dry fronts over complex topography, Comput. Fluids, vol.38, pp.221-234, 2009. ,
Numerical resolution of well-balanced shallow water equations with complex source terms, Adv. Water Resour, vol.32, pp.873-884, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00799080
Unsteady free surface flow simulation over complex topography with a multidimensional upwind technique, J. Comput. Phys, vol.186, issue.2, pp.503-526, 2003. ,
Application of conservative residual distribution schemes to the solution of the shallow water equations on unstructured meshes, J. Comput. Phys, vol.222, pp.287-331, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00402580
Stabilized residual distribution for shallow water simulations, J.Comput.Phys, vol.228, pp.1071-111, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00538892
On the c-property and generalized c-property of residual distribution for the shallow water equations, Journal of Scientific Computing, vol.48, pp.304-318, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00538844
An explicit residual based approach for shallow water flows, J.Comput.Phys, vol.80, pp.306-344, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01087940
3d transient fixed point mesh adaptation for time dependent problems. application to cfd simulations, J. Comp. Phys, vol.222, pp.592-623, 2007. ,
Arbitrary lagrangian eulerian formulation for two-dimensional flows using dynamic meshes with edge swapping, J. Comp. Phys, vol.230, pp.7706-7722, 2011. ,
Adaptive mesh methods for one and two-dimensional hyperbolic conservation laws, SIAM J. Numer. Anal, vol.41, issue.2, pp.487-515, 2003. ,
Adaptivity with moving grids, pp.1-131, 2009. ,
Fundamental concepts and approaches, Hanbook of Grid Generation, 1999. ,
Numerical solution of the quasi-linear poisson equation, J. Comput. Phys, vol.1, pp.149-172, 1967. ,
An ecient dynamically adaptive mesh for potentially singular solutions, J. Comput. Phys, vol.172, pp.609-639, 2008. ,
Monge-ampere based moving mesh methods for numerical weather prediction, with applications to the eady problem, 2012. ,
Anisotropic mesh adaptation and movement, Workshop on Adaptive Method, Theory and Application, 2005. ,
Adaptive zoning for singular problems in two dimensions, J. Comput. Phys, vol.46, p.342, 1982. ,
A high-order moving mesh kinetic scheme based on weno reconstruction for compressible flows on unstructured meshes, J. Comp. Phys, vol.57, pp.278-299, 2013. ,
Unsteady flow simulation using a zonal multigrid approach with moving boundaries, pp.94-0057, 1994. ,
Geometric conservation laws for flow problems with moving boundaries and deformable meshes, and their impact on aeroelastic computations, Comput. Method Appl. M, vol.134, issue.1-2, pp.71-90, 1996. ,
An adaptive moving finite volume scheme for modelling flood inundation over dry and complex topography, Water Resour. Res, vol.49, pp.1914-1928, 2013. ,
A well-balanced stable grp scheme for shallow water equations for adaptive unstructured triangular meshes, Int J Numer Meth Fl, vol.73, pp.266-283, 2013. ,
Arbitrary lagrangian eulerian finite element methods. In Computational Methods for Transient Analysis, chapter 10, 1983. ,
An unstructured node-centered finite volume scheme for shallow water flows with wet/dry fronts over complex topography, Comput.Methods Appl.Mech.Engrg, vol.198, pp.3723-3750, 2009. ,
A fast and stable well-balanced scheme with hydrostatic reconstruction or shallow water flows, SIAM J. Sci. Comput, vol.25, issue.6, pp.2050-2065, 2004. ,
An ale formulation for explicit runge-kutta residual distribution, J. Sci. Comput, vol.190, issue.34, pp.1467-1482, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00863154
An Interpolation Free Two-Dimensional Conservative ALE scheme over Adaptive Unstructured Grids for Rotorcraf Aerodynamics ,
Performance and comparison of cell-centered and node-centered unstructured finite volume discretizations for shallow water free surface flows, Archives of Computational Methods in Engineering, vol.18, issue.1, pp.57-118, 2011. ,
High-resolution methods, Finite Volume Methods for Hyperbolic problems, 2004. ,
URL : https://hal.archives-ouvertes.fr/hal-01342271
A numerical model for the flooding and drying of irregular domains, Int. J. Numer. Meth. Fluids, vol.39, pp.247-275, 2002. ,
Zero mass error using unsteady wetting-drying conditions in shallow flows over dry irregular topography, Int. J. Numer. Meth. Fluids, vol.45, pp.1047-1082, 2004. ,
A robust high-resolution finite volume scheme for the simulation of long waves over complex domains, Int. J. Numer. Meth. Fluids, vol.56, pp.419-452, 2008. ,
Explicit Runge-Kutta residual distribution schemes for time dependent problems: Second order case, J. Comput. Phys, vol.229, issue.16, pp.5653-5691, 2010. ,
DOI : 10.1016/j.jcp.2010.04.002
URL : https://hal.archives-ouvertes.fr/inria-00406958
Streamline upwind Petrov-Galerkin formulations for convection dominated flows with particular emphasis on the incompressible Navier-Stokes equations, Comp. Meth. Appl. Mech. Engrg, vol.32, pp.199-259, 1982. ,
Stabilized methods for compressible flows, J. Sci. Comp, vol.43, pp.343-368, 2010. ,
DOI : 10.1007/s10915-008-9233-5
Essentially non oscillatory residual distribution schemes for hyperbolic problems, J. Comput. Phys, vol.214, issue.2, pp.773-808, 2006. ,
Multidimensional upwinding for grid adaptation. Numerical Methods for Wave Propagation, pp.33-54, 1998. ,
DOI : 10.1007/978-94-015-9137-9_2
Second-order accurate godunov scheme for multicomponent flows on moving triangular meshes, J. Sci. Comput, vol.34, pp.64-86, 2008. ,
DOI : 10.1007/s10915-007-9162-8
A moving mesh finite element algorithm for signular problems in two and three space dimensions ,
DOI : 10.1006/jcph.2002.7002
On the use of moving mesh methods to solve pdes, Adaptive Computations: Theory and Algorithms, pp.242-278, 2007. ,
Non-oscillatory relaxation methods for the shallow water equations in one and two space dimensions, Int. J. for Numerical Methods in Fluids, vol.46, pp.457-484, 2004. ,
, Laboratory experiments of tsunami runup on a circular island. Pure Appl. Geophys, vol.144, pp.569-593, 1995.
, Advanced Numerical Models for Simulating Tsunami Waves and Runup, vol.10, 2008.
DOI : 10.1142/6226
Tsunami runup onto a complex three-dimensional beach ,
Experimental study of a solitary wave evolution over a 3d shallow shelf, Proc. 32th Conf. Coast. Engng, p.813, 2010. ,
Boussinesq-type model for energetic breaking waves in fringing reef environments, Coast. Eng, vol.70, pp.1-20, 2012. ,
DOI : 10.1016/j.coastaleng.2012.06.001
Numerical treatment of wave-breaking on unstructured finite volume approximations for extended boussinesq-type equations, J.Comput.Phys, vol.271, pp.281-305, 2014. ,
DOI : 10.1016/j.jcp.2014.01.030
A flexible genuinely nonlinear approach for nonlinear wave propagation, breaking and run-up, J.Comput.Phys, vol.310, pp.381-417, 2016. ,
DOI : 10.1016/j.jcp.2016.01.027
Automatic mesh update with the solid-extension mesh moving technique, Comput. Method Appl. M, vol.193, pp.2019-2032, 2004. ,
DOI : 10.1016/j.cma.2003.12.046
A method for computing curved meshes via the linear elasticity analogy, application to fluid dynamics problems, Int. J. Numeric. Meth. Fl, vol.76, issue.4, pp.246-266, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01045103
