Real time monitoring of the quiescent suspension copolymerization of vinyl chloride with methyl methacrylate in microreactors – Part 3. A kinetic study by raman spectroscopy and evolution of droplet size - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Chemical Engineering Science Année : 2017
The present work presents results on the copolymerization kinetics of methyl methacrylate (MMA) and vinyl chloride (VCM) monitored by Raman spectroscopy and on the evolution of droplets as captured by charge-coupled device (CCD) camera in a microcapillary reactor. Different experimental recipes were proposed using commercial initiators in order to compare the system performance when initiated with monofunctional and bifunctional peroxides. The experimental setup was able to capture the distinct stages of the copolymerization within a microreactor up to high conversions (>90%) in quiescent state. It is shown that the copolymerization of MMA with VCM leads to distinct morphological structures, when compared to VCM homopolymerization, forming a core and a shell after a certain critical conversion. A new mechanism is proposed for the copolymerization based on the results from both video camera and Raman spectroscopy.
Castor_20404.pdf (1.49 Mo) Télécharger le fichier
hal-01939182 , version 1 (24-05-2019)
C. A. Castor Jr., Alain Pontier, Jérôme J. Durand, J. C. Pinto, Laurent Prat. Real time monitoring of the quiescent suspension copolymerization of vinyl chloride with methyl methacrylate in microreactors – Part 3. A kinetic study by raman spectroscopy and evolution of droplet size. Chemical Engineering Science, 2017, 173, pp.493-506. ⟨10.1016/j.ces.2017.08.018⟩. ⟨hal-01939182⟩
165 Consultations
186 Téléchargements
