Energy efficient MIMO processing: A case study of opportunistic run-time approximations, IEEE/ACM Conference on Design, Automation and Test in Europe, pp.1-6, 2014. ,
DSP Processor Fundamentals: Architectures and Features, 1996. ,
Power Consumption Models for the Use of Dynamic and Partial Reconfiguration. Microprocessors and Microsystems, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00941532
Ultra Low Energy Domain Specific Instruction-set Processor for On-line Surveillance, IEEE 8th Symposium on Application Specific Processors (SASP), pp.30-35, 2010. ,
URL : https://hal.archives-ouvertes.fr/lirmm-02089553
AnySP: anytime anywhere anyway signal processing, 36th Annual International Symposium on Computer Architecture, pp.128-139, 2009. ,
, Efficient Embedded Computing. Computer, vol.41, issue.7, pp.27-32, 2008.
Understanding Sources of Inefficiency in GeneralPurpose Chips, 37th Annual International Symposium on Computer Architecture, 2010. ,
CoolFlux DSP: The embedded ultra low power Cprogrammable DSP core, Proc. Int. Signal Proc. Conf. (GSPx), 2004. ,
High-level synthesis with SIMD units, 7th Asia and South Pacific Design Automation Conference, pp.407-413, 2002. ,
, TMS320C64x/C64x+ DSP CPU and Instruction Set Reference Guide, 2006.
A coarse-grained array accelerator for software-defined radio baseband processing, IEEE micro, vol.28, issue.4, pp.41-50, 2008. ,
Vector processing as an enabler for software-defined radio in handheld devices, EURASIP Journal on Applied Signal Processing, vol.16, p.2613, 2005. ,
Floating-to-fixed-point conversion for digital signal processors, EURASIP Journal on Applied Signal Processing, vol.14, 2006. ,
Scenario-based fixed-point data format refinement to enable energy-scalable software defined radios, IEEE/ACM Conference on Design, Automation and Test in Europe, pp.722-727, 2008. ,
URL : https://hal.archives-ouvertes.fr/lirmm-02089059
, Implementing SIMD in Software, 2006.
Enabling WordWidth Aware Energy and Performance Optimizations for Embedded Processors, Workshop on ODES, 2007. ,
The complexity of multiple wordlength assignment, Applied Mathematics Letters, vol.15, issue.2, pp.137-140, 2002. ,
Wordlength Optimization for Linear Digital Signal Processing, IEEE Transactions on Computer-Aided Design of Integrated Circuits and Systems, vol.22, issue.10, pp.1432-1442, 2003. ,
A Comparison of Automatic Word Length Optimization Procedures, IEEE Int. Symposium on Circuits and Systems, vol.2, pp.612-615, 2002. ,
Simulated-annealing-based optimization of coefficient and data word-lengths in digital filters, International Journal of Circuit Theory and Applications, vol.I, pp.371-390, 1988. ,
Word-length determination and scaling software for a signal flow block diagram, IEEE International Conference on Acoustics, Speech, and Signal Processing, pp.457-460, 1994. ,
Word-length selection for power minimization via nonlinear optimization, ACM Trans Des Autom Electron Syst, vol.14, issue.3, pp.1-28, 2009. ,
Accuracy Constraint Determination in FixedPoint System Design, EURASIP Journal on Embedded Systems, p.12, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00459254
Analytical Approach for Numerical Accuracy Estimation of Fixed-Point Systems Based on Smooth Operations, IEEE Transactions on Circuits and Systems I: Regular Papers, pp.1-14, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00741741
Fast Integer Word-length Optimization for Fixed-point Systems, Journal of Signal Processing Systems, pp.1-16, 2015. ,
Interval analysis. Prentice-Hall series in automatic computation, N.J, 1966. ,
, Use and Limits. Reliable Computing, vol.9, pp.43-79, 2002.
FRIDGE: An Interactive Fixed-Point Code Generation Environment for Hw/Sw-Codesign, Int. Conf. Acoustics, Speed, 1997. ,
FRIDGE: A Fixed-Point Design and Simulation Environment, IEEE/ACM Design, Automation and Test in Europe (DATE), pp.429-435, 1998. ,
PROFIL/BIAS-A fast interval library. Computing, vol.53, pp.277-287, 1994. ,
Motivations for an Arbitrary Precision Interval Arithmetic and the MPFI Library. Reliable Computing, vol.11, pp.275-290, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00100985
The design of the Boost interval arithmetic library, Theoretical Computer Science, vol.351, issue.1, pp.111-118, 2006. ,
Automatic Data Path Abstraction for Verification of Large Scale Designs, IEEE International Conference on Computer Design ,
Evaluacion de los Efectos de Cuantificacion en las Estructuras de Filtros Digitales Utilizando Tecnicas de Cuantificacion Basadas en Extensiones de Intervalos ,
, , 2004.
Accuracy-Guaranteed Bit-Width Optimization, IEEE Transactions on Computer-Aided Design of Integrated Circuits and Systems, vol.25, issue.10, pp.1990-2000, 2006. ,
Fast, accurate static analysis for fixed-point finiteprecision effects in DSP designs, In: Int. Conf. on Computer-Aided Design, pp.275-282, 2003. ,
A Methodology and Design Environment for DSP ASIC Fixed Point Refinement, IEEE/ACM conference on Design, Automation and Test in, pp.271-276, 1999. ,
Bit-width selection for data-path implementations, 12th International Symposium on System Synthesis (ISSS), pp.114-119, 1999. ,
Bit-Width Optimization for Configurable DSPs by Multiinterval Analysis, IEEE Asilomar Conf. on Signals, 2000. ,
Fast characterization of the noise bounds derived from coefficient and signal quantization, International Symposium on Circuits and Systems (ISCAS), vol.4, pp.309-312, 2003. ,
Affine Arithmetic and Its Applications to Computer Graphics, VI Brazilian Symp. on Comp. Graphics and Image Processing, pp.9-18, 1993. ,
Computer Arithmetic, and Validated Numerics (SCAN), Affine Arithmetic: Concepts and Applications. 10th GAMM/IMACS International Symposium on Scientific Computing, 2002. ,
Self-validated numerical methods and applications, Brazilian Mathematics Colloquium, p.21, 1997. ,
Toward efficient static analysis of finiteprecision effects in DSP applications via affine arithmetic modeling, IEEE/ACM Design Automation Conference (DAC), pp.496-501, 2003. ,
Accuracy-Guaranteed Bit-Width Optimization, IEEE Trans on Computer-Aided Design of Integrated Circuits and Systems, vol.25, issue.10, pp.1990-2000, 2006. ,
Floating-Point Error Analysis Based on Affine Arithmetic, IEEE Int. Conf. on Acoustics, Speech, and Signal Processing, vol.2, pp.561-564, 2003. ,
An automated, efficient and static bit-width optimization methodology towards maximum bit-width-to-error tradeoff with affine arithmetic model, Asia and South Pacific Design Automation Conf. (ASP-DAC), pp.886-891, 2006. ,
Improved Interval-Based Characterization of Fixed-Point LTI Systems With Feedback Loops, IEEE Transactions on Computer-Aided Design of Integrated Circuits and Systems, vol.26, issue.11, pp.1923-1933, 2007. ,
Modified Affine Arithmetic Is More Accurate than Centered Interval Arithmetic or Affine Arithmetic, 10th IMA International Conference on Mathematics of Surfaces, vol.2768, pp.355-365, 2003. ,
Modified affine arithmetic in tensor form for trivariate polynomial evaluation and algebraic surface plotting, Journal of Computational and Applied Mathematics, vol.195, issue.1, pp.155-171, 2006. ,
Interval-based analysis and word-length optimization of non-linear systems with control-flow structures, The 7th International Conference on Computational Methods (ICCM), vol.3, pp.1333-1342, 2016. ,
Quantization Analysis of the Infrared Interferometer of the TJ-II Stellarator for its Optimized FPGA-Based Implementation, IEEE Transactions on Nuclear Science, vol.60, issue.5, pp.3592-3596, 2013. ,
Dynamic Range Estimation, IEEE Trans on Computer-Aided Design of Integrated Circuits and Systems, vol.25, issue.9, pp.1618-1636, 2006. ,
Fast and accurate computation of the roundoff noise of linear time-invariant systems. IETCircuits, Devices and Systems, vol.2, pp.393-408, 2008. ,
An adaptive multi-element generalized polynomial chaos method for stochastic differential equations, Journal of Computational Physics, vol.209, issue.2, pp.617-642, 2005. ,
DOI : 10.1016/j.jcp.2005.03.023
Computer-Based Exercises for Signal Processing Using Matlab 5. Matlab Curriculum Series, 1998. ,
Techniques for Estimating the Bit Error Rate in the Simulation of Digital Communication Systems, IEEE Journal on Selected Areas in Communications, vol.2, issue.1, pp.153-170, 1984. ,
Quick Simulation: A Review of Importance Sampling Techniques in Communications Systems, IEEE Journal Selected Areas Comm, vol.15, issue.4, pp.597-613, 1997. ,
A Comparison of Failure Probability Estimates by MonteCarlo Sampling and Latin Hypercube Sampling, 1998. ,
Fixed-Point Optimization Utility for C and C++ Based Digital Signal Processing Programs, Workshop on VLSI and Signal Processing, 1995. ,
An Automatic Word Length Determination Method, IEEE Int. Symp. on Circuits and Systems (ISCAS). vol, vol.5, pp.53-56, 2001. ,
DOI : 10.1109/iscas.2001.921982
URL : http://www.wseas.us/e-library/conferences/crete2004/papers/476-330.pdf
Saphire Technical Reference Manual: IRRAS/SARA Version 4.0. EG&G Idaho Inc, 1992. ,
DOI : 10.2172/10120495
A Topical Dictionary of Statistics, 1986. ,
Engineering Statistics, 1972. ,
, , 2010.
Pain Killers for the Fixed-Point Design Flow. Synopsys, 2010. ,
Fixed-Point Blockset User's Guide (ver. 2.0), 2001. ,
Taming Heterogeneity, the Ptolemy Approach, Proceedings of the IEEE, vol.91, 2003. ,
DOI : 10.1109/jproc.2002.805829
A comparison of three methods for selection values of input variables in the analysis of output from a computer code, Technometrics, vol.22, issue.2, pp.239-245, 1979. ,
Latin Hipercube Sampling as a Tool in Uncertainty Analysis of Computer Models, pp.557-564, 1992. ,
A Modified Monte-Carlo Simulation Technique for the Evaluation of Error Rate in Digital Communication Systems, IEEE Trans Commun, vol.28, issue.11, pp.1916-1924, 1980. ,
On Efficient BER Evaluation of Digital Communication Systems via Importance Sampling, 8th IEEE Symposium on Communications and Vehicular Technology ,
On the Choice of Alternative Measures in Importance Sampling with Markov Chains, Oper REs, vol.43, issue.3, pp.509-519, 1995. ,
On Large Deviations Theory and Asymptotically Efficient Monte-Carlo Estimation, IEEE Trans Inform Theory, vol.36, pp.579-588, 1990. ,
On the Optimality and Stability of Exponential Twisting in Monte-Carlo Simulation, IEEE Trans Inform Theory, vol.39, pp.119-128, 1993. ,
Importance Sampling for TCM Scheme over Non-gausian Channel, IEICE Trans Fundamentals of Electron Commun and Comput Sci, vol.78, issue.9, pp.1109-1116, 1995. ,
Constrained Solutions in Importance Sampling via Robust Statistics, IEEE Trans Inform Theory, vol.37, pp.307-316, 1991. ,
Adaptative Importance Sampling, IEEE Journal Selected Areas Comm, vol.11, issue.3, pp.309-316, 1993. ,
Statistics of Extremes, 1958. ,
Theory and Application of some Classical and Generalized Asymptotic Distributions of Extreme Values, IEEE Trans Inform Theory, vol.19, 1973. ,
Interval methods for modeling uncertainty in ¡e1¿RC¡/e1¿ timing analysis. IEEE Transactions onComputer-Aided Design of Integrated Circuits and Systems, vol.11, pp.1388-1401, 1992. ,
Probabilistic interval-valued computation: toward a practical surrogate for statistics inside CAD tools, 43rd ACM/IEEE Design Automation Conference, pp.167-172, 2006. ,
Fast and accurate computation of the roundoff noise of linear time-invariant systems. IET Circuits, Devices and Systems, vol.2, pp.393-408, 2008. ,
Automated wordlength optimization framework for multi-source statistical interval-based analysis of nonlinear systems with control-flow structures ,
, , 2016.
Analytical Fixed-Point Accuracy Evaluation in Linear Time-Invariant Systems, IEEE Transactions on Circuits and Systems I: Regular Papers, vol.55, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00459231
Analytical Optimization of Bit-Widths in Fixed-Point LTI Systems, IEEE Transactions on Computer-Aided Design of Integrated Circuits and Systems, vol.31, issue.3, pp.343-355, 2012. ,
A Scalable Precision Analysis Framework, IEEE Transactions on Multimedia, vol.15, issue.2, pp.242-256, 2013. ,
Accuracy Sensitive Word-Length Selection for Algorithm Optimization, Int. Conf. on Computer Design (ICCD), pp.54-61, 1998. ,
Architectural Synthesis of Fixed-Point DSP Datapaths Using FPGAs, Int J of Reconfigurable Computing, pp.1-14, 2009. ,
Data Wordlength Optimization for FPGA Synthesis, Proc. IEEE International Workshop on Signal Processing Systems, (SIPS). Athens, pp.623-628, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00482912
From MIMO-OFDM Algorithms to a RealTime Wireless Prototype: A Systematic Matlab-to-Hardware Design Flow, EURASIP Journal on Applied Signal Processing, pp.1-12, 2006. ,
A Hierarchical Methodology for Word-Length Optimization of Signal Processing Systems, 23rd International Conference on VLSI Design (VLSID), pp.318-323, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00432590
Optimum Wordlength Search Using Sensivity Information, EURASIP Journal of Applied Signal Processing, pp.1-14, 2006. ,
Optimal Combined Word-Length Allocation and Architectural Synthesis of Digital Signal Processing Circuits, IEEE Transactions on Circuits and Systems II, vol.53, issue.5, pp.339-343, 2006. ,
Closed-form and real-time wordlength adaptation, IEEE International Conference on Acoustics, Speech, and Signal Processing, vol.4, pp.1897-1900, 1999. ,
Minimization of fractional wordlength on fixedpoint conversion for high-level synthesis, Asia and South Pacific Design Automation Conference, pp.80-85, 2004. ,
Efficient Approximate Wordlength Optimization, IEEE Transactions on Computers, vol.57, issue.11, pp.1561-1570, 2008. ,
Truncation Noise in Fixed-Point SFGs, IEE Electronics Letters, vol.35, issue.23, pp.2012-2014, 1999. ,
A Custom Computing Framework for Orientation and Photogrammetry, 2000. ,
Combined Word-Length Allocation and High-Level Synthesis of Digital Signal Processing Circuits, 2008. ,
Search-based Wordlength Optimization for VLSI/DSP Synthesis, IEEE Workshop VLSI Signal Processing, pp.198-207, 1994. ,
Simulation-Based Word-Length Optimization Method for FixedPoint Digital Signal Processing Systems, IEEE Transactions on Signal Processing, vol.43, issue.12, pp.3087-3090, 1995. ,
Numerical word-length optimization for CDMA demodulator, IEEE International Symposium on Circuits and Systems (ISCAS), vol.4, pp.290-293, 2001. ,
Data Wordlength Reduction for Low-Power Signal Processing Software, IEEE Workshop on Signal Processing Systems, pp.343-348, 2004. ,
Floating-Point Bit-Width Optimization for Low-Power Signal Processing Applications, IEEE Int. Conf. Acoustics, Speech, and Signal Processing, vol.3, pp.3208-3211, 2002. ,
Novel Algorithms for Word-length Optimization, 19th European Signal Processing Conference (EUSIPCO-2011), 2011. ,
Optimal design of state-space digital filters by simultaneous minimization of sensitivity and roundoff noise, IEEE Transactions on Circuits and Systems, vol.31, issue.10, pp.884-888, 1984. ,
Design of sensitivity and round-off noise optimal state-space discrete systems, Int J Circuit Theory Appl, vol.12, pp.39-46, 1984. ,
Algorithm to System-on-Chip Design Flow that Leverages System Studio and SystemC 2.0.1, 2004. ,
Fixed-point optimization utility for C and C++ based digital signal processing programs, IEEE Transactions on Circuits and Systems II-Analog and Digital Signal Processing, vol.45, pp.1455-1464, 1998. ,
, Mentor Graphics. Algorithmic C Data Types, 2008.
Code Generation for Compiled Bit-True Simulation of DSP Applications, IEEE International Symposium on System Synthesis (ISSS), pp.9-14, 1998. ,
Fast Bit-True Simulation, ACM/IEEE Design Automation Conference (DAC), pp.708-713, 2001. ,
Affine arithmetic: Concepts and applications, Numerical Algorithms, vol.37, issue.1, pp.147-158, 2004. ,
Introduction to Interval Computations, 1983. ,
Fixed CADNA library, Conference on Real Number Conference (RNC), pp.215-221, 2003. ,
URL : https://hal.archives-ouvertes.fr/hal-01531071
Automatic Evaluation of the Accuracy of Fixed-point Algorithms, IEEE/ACM Design, Automation and Test in Europe (DATE), 2002. ,
URL : https://hal.archives-ouvertes.fr/inria-00482931
A Perturbation Theory on Statistical Quantization Effects in Fixed-Point DSP with Non-Stationary Inputs, IEEE Int. Symp. on Circuits and Systems (ISCAS). vol, vol.3, pp.373-376, 2004. ,
SQNR Estimation of Fixed-Point DSP Algorithms, Int J on Advances in Signal Processing, vol.2010, pp.1-11, 2010. ,
DOI : 10.1155/2010/171027
URL : https://asp-eurasipjournals.springeropen.com/track/pdf/10.1155/2010/171027
Leveraging Power Spectral Density for Scalable System-Level Accuracy Evaluation, IEEE/ACM Conference on Design Automation and Test in Europe (DATE), p.6, 2016. ,
DOI : 10.3850/9783981537079_0204
URL : https://hal.archives-ouvertes.fr/hal-01253494
Roundoff-noise shaping in filter design, IEEE International Symposium on Circuits and Systems (ISCAS), vol.4, pp.57-60, 2000. ,
DOI : 10.1109/iscas.2000.858687
URL : http://cas.ee.ic.ac.uk/people/gac1/pubs/GeorgeISCAS00.pdf
Statistical Analysis of Amplitude Quantized Sampled-Data Systems, Transaction on AIEE, Part II: Applications and Industry, vol.79, pp.555-568, 1960. ,
DOI : 10.1109/tai.1961.6371702
Quantization Mode Opportunities in FixedPoint System Design, 18th European Signal Processing Conference (EUSIPCO2010), pp.542-546, 2010. ,
URL : https://hal.archives-ouvertes.fr/lirmm-02089546
A Discrete Model for Correlation Between Quantization Noises, IEEE Transactions on Circuits and Systems Part 2 Analog and Digital Signal Processing, 2012. ,
DOI : 10.1109/tcsii.2012.2222838
URL : https://hal.archives-ouvertes.fr/hal-00743413
Word-length optimization for differentiable nonlinear systems, ACM Transactions on Design Automation of Electronic Systems, vol.11, issue.1, pp.26-43, 2006. ,
DOI : 10.1145/1124713.1124716
Analytical accuracy evaluation of Fixed-Point Systems, Proc. European Signal Processing Conference (EUSIPCO), 2007. ,
URL : https://hal.archives-ouvertes.fr/inria-00454534
SQNR Determination in Non-Linear and Non-Recursive Fixed-Point Systems, European Signal Processing Conference, pp.1349-1352, 2004. ,
URL : https://hal.archives-ouvertes.fr/inria-00482941
Accelerated Performance Evaluation of FixedPoint Systems With Un-Smooth Operations, IEEE Transactions on Computer-Aided Design of Integrated Circuits and Systems, vol.33, issue.4, pp.599-612, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01097606
