A generic fuzzy approach for multi-objective optimization under uncertainty - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Swarm and Evolutionary Computation Année : 2018
Multi-objective optimization under uncertainty has gained considerable attention in recent years due to its practical applications in real-life. Many studies have been conducted on this topic, but almost all of them transformed the problem into a mono-objective one or just neglected the effects of uncertainty on the outcomes. This paper addresses specific uncertain multi-objective problems in which uncertainty is expressed by means of triangular fuzzy numbers. To handle these problems, we introduced a new approach able to solve them without any transformation by considering fuzziness propagation to the objective functions. The proposed approach is composed of two main contributions: First, a fuzzy Pareto dominance is defined for ranking the generated fuzzy solutions. Second, a generic fuzzy extension of well-known evolutionary algorithms is suggested as resolution methods. An experimental study on multi-objective Vehicle Routing Problems (VRP) with uncertain demands is finally carried to evaluate our approach.
Fichier non déposé
hal-01942402 , version 1 (03-12-2018)
Oumayma Bahri, El-Ghazali Talbi, Nahla Ben Amor. A generic fuzzy approach for multi-objective optimization under uncertainty. Swarm and Evolutionary Computation, 2018, 40, pp.166-183. ⟨10.1016/j.swevo.2018.02.002⟩. ⟨hal-01942402⟩
69 Consultations
0 Téléchargements
