Inferring Biochemical Reactions and Metabolite Structures to Understand Metabolic Pathway Drift - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue iScience Année : 2020
Inferring genome-scale metabolic networks in emerging model organisms is challenged by incomplete biochemical knowledge and partial conservation of biochemical pathways during evolution. Therefore, specific bioinformatic tools are necessary to infer biochemical reactions and metabolic structures that can be checked experimentally. Using an integrative approach combining genomic and metabolomic data in the red algal model Chondrus crispus, we show that, even metabolic pathways considered as conserved, like sterols or mycosporine-like amino acid synthesis pathways, undergo substantial turnover. This phenomenon, here formally defined as “metabolic pathway drift,” is consistent with findings from other areas of evolutionary biology, indicating that a given phenotype can be conserved even if the underlying molecular mechanisms are changing. We present a proof of concept with a methodological approach to formalize the logical reasoning necessary to infer reactions and molecular structures, abstracting molecular transformations based on previous biochemical knowledge.
Belcour2020.pdf (9.98 Mo) Télécharger le fichier
hal-01943880 , version 1 (04-12-2018)
hal-01943880 , version 2 (24-02-2020)
Paternité - Pas d'utilisation commerciale - Pas de modification
Arnaud Belcour, Jean Girard, Méziane Aite, Ludovic Delage, Camille Trottier, et al.. Inferring Biochemical Reactions and Metabolite Structures to Understand Metabolic Pathway Drift. iScience, 2020, 23 (2), pp.100849. ⟨10.1016/j.isci.2020.100849⟩. ⟨hal-01943880v2⟩
442 Consultations
324 Téléchargements
