An algorithm for cost optimization of PMU and communication infrastructure in WAMS
Power system state estimation relies increasingly on PMU measurements to ef-
fectively control and monitor growing and stressed transmission networks which
are also affected by transient and dynamic events. High PMU cost has moti-
vated optimal PMU placement solutions but recent works have shown the effect
of communication infrastructure cost in PMU configuration. In this paper,
we present a new method for the design of Wide Area Measurement Systems.
A topological analysis algorithm based on the Variable Neighbourhood Search
heuristic is proposed and tested in several networks, including the common IEEE
test networks and the 5804-bus Brazilian transmission system. Our results show
the flexibility, effectiveness, and scalability of the proposed methodology when
compared with recent research presented in the literature.
