Numerical simulation of the fractional flow reserve (FFR) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Modelling of Natural Phenomena Année : 2018
The fractional ow reserve (FFR) provides an efficient quantitative assessment of the severity of a coronary lesion. Our aim is to address the problem of computing non-invasive virtual fractional ow reserve (VFFR). In this paper, we present a preliminary study of the main features of ow over a stenosed coronary arterial portion, in order to enumerate the different factors affecting the VFFR. We adopt a non-Newtonian ow model and we assume that the two-dimensional (2D) domain is rigid in a first place. In a second place, we consider a simplified weakly coupled FSI model in order to take into account the infinitesimal displacements of the upper wall. A 2D finite element solver was implemented using Freefem++. We computed the VFFR profiles with respect to different lesion parameters and compared the results given by the rigid wall model to those obtained for the elastic wall one.
mmnp180018_proof-1.pdf (1.84 Mo) Télécharger le fichier
hal-01944566 , version 1 (04-12-2018)
  • HAL Id : hal-01944566 , version 1
Keltoum Chahour, Rajae Aboulaich, Abderrahmane Habbal, Cherif Abdelkhirane, Nejib Zemzemi. Numerical simulation of the fractional flow reserve (FFR). Mathematical Modelling of Natural Phenomena, inPress, Special issue "Mathematical Modelling in Cardiology". ⟨hal-01944566⟩
211 Consultations
408 Téléchargements
