An immersed boundary method with formal second-order accuracy and reduced numerical viscosity, J. Comp. Phys, vol.160, issue.2, pp.705-719, 2000. ,
A combined fictitious domain/adaptive meshing method for fluid-structure interaction in heart valves, Int. J. Num. Meth. Fluids, vol.46, issue.5, pp.533-544, 2004. ,
An immersogeometric variational framework for fluid-structure interaction: application to bioprosthetic heart valves, Comput. Methods Appl. Mech. Eng, vol.284, pp.1005-1053, 2015. ,
A coupled mitral valve-left ventricle model with fluid-structure interaction, Med. Eng. Phys, vol.47, pp.128-136, 2017. ,
A robust and efficient valve model based on resistive immersed surfaces, Int. J. Numer. Meth. Biomed. Engng, vol.28, issue.9, pp.937-959, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00717213
Image-Based Simulations Show Important Flow Fluctuations in a Normal Left Ventricle: What Could be the Implications?, Ann. Biomed. Eng, vol.44, issue.11, pp.3346-3358, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01303067
A patient-specific aortic valve model based on moving resistive immersed implicit surfaces, Biomech. Model. Mechanobiol, vol.16, issue.5, pp.1779-1803, 2017. ,
Fluid dynamics of an idealized left ventricle: the extended Nitsche's method for the treatment of heart valves as mixed time varying boundary conditions, Int. J. Num. Meth. Fluids, vol.85, issue.3, pp.135-164, 2017. ,
Numerical simulation of blood flows through a porous interface, M2AN Math. Model. Numer. Anal, vol.42, issue.6, pp.961-990, 2008. ,
Projection Schemes for Fluid Flows through a Porous Interface, SIAM Jour. on Sc. Comp, vol.33, issue.2, pp.541-564, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00462103
The Cardiac Cycle and the Physiological Basis of Left Ventricular Contraction, Ejection, Relaxation, and Filling, Heart Failure Clin, vol.4, issue.1, pp.1-11, 2008. ,
Coupling schemes for the FSI forward prediction challenge: comparative study and validation, Int. J. Numer. Meth. Biomed. Engng, vol.33, issue.4, p.2813, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01239931
Morphology of the Human Mitral Valve: II. The Valve Leaflets, Circulation, vol.41, issue.3, pp.459-467, 1970. ,
Studies of the mitral valve. I. Anatomic features of the normal mitral valve and associated structures, Circ, vol.6, issue.6, pp.825-831, 1952. ,
The anatomy of the mitral valve and its associated structures, Thorax, vol.19, pp.221-227, 1964. ,
Mitral Annular Dimensions and Geometry in Patients With Functional Mitral Regurgitation and Mitral Valve Prolapse, JACC: Card. Imag, vol.9, issue.3, pp.269-280, 2016. ,
Mitral valve finite-element modelling from ultrasound data: a pilot study for a new approach to understand mitral function and clinical scenarios, Phil. Trans. A Math. Phys. Eng. Sci, vol.366, pp.3411-3445, 1879. ,
Normal resting pulse rate ranges, J. Nurs. Educ. Pract, vol.5, issue.8, 2015. ,
Energy-Preserving Muscle Tissue Model: Formulation and Compatible Discretizations, Int. J. for Multi. Comp. Engng, vol.10, issue.2, pp.189-211, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00678772
Congenital Hearts Alliance (MOCHA) oM. A comparison of outlet boundary treatments for prevention of backflow divergence with relevance to blood flow simulations, Comput. Mech, vol.48, issue.3, pp.277-291, 2011. ,
Value of systolic and diastolic time intervals. Studies in normotensive and hypertensive 50-year-old men and in patients after myocardial infarction, Br. Heart J, vol.40, issue.3, pp.256-267, 1978. ,
Combined experimental and numerical analysis of the flow structure into the left ventricle, J. Biomech, vol.40, issue.9, pp.1988-1994, 2007. ,
