Nonlinear Approximations in Cryptanalysis Revisited - Archive ouverte HAL Access content directly
Journal Articles IACR Transactions on Symmetric Cryptology Year : 2018
(1) , (2) , (3)
1
2
3
This work studies deterministic and non-deterministic nonlinear approximations for cryptanalysis of block ciphers and cryptographic permutations and embeds it into the well-understood framework of linear cryptanalysis. For a deterministic (i.e., with correlation ±1) nonlinear approximation we show that in many cases, such a nonlinear approximation implies the existence of a highly-biased linear approximation. For non-deterministic nonlinear approximations, by transforming the cipher under consideration by conjugating each keyed instance with a fixed permutation, we are able to transfer many methods from linear cryptanalysis to the nonlinear case. Using this framework we in particular show that there exist ciphers for which some transformed versions are significantly weaker with regard to linear cryptanalysis than their original counterparts.
7362-Article Text-2508-1-10-20181213.pdf (643.33 Ko) Télécharger le fichier
Dates and versions
hal-01944995 , version 1 (05-12-2018)
hal-01944995 , version 2 (28-12-2018)
Identifiers
Cite
Christof Beierle, Anne Canteaut, Gregor Leander. Nonlinear Approximations in Cryptanalysis Revisited. IACR Transactions on Symmetric Cryptology, 2018, 2018 (4), pp.80-101. ⟨10.13154/tosc.v2018.i4.80-101⟩. ⟨hal-01944995v2⟩
Collections
INRIA INRIA2
80 View
230 Download
Share
