Armarkov least-squares identification, American Control Conference, vol.1, pp.186-190, 1997. ,
The vibrating ribbon problem revisited, Journal of Fluid Mechanics, vol.213, pp.531-547, 1990. ,
Input-output analysis and control design applied to a linear model of spatially developing flows, Applied Mechanics Reviews, vol.62, issue.2, p.803, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-01002594
Feedback control of instabilities in the two-dimensional blasius boundary layer: the role of sensors and actuators, Physics of Fluids, vol.25, issue.5, p.106, 1994. ,
Random data: analysis and measurement procedures, vol.729, 2011. ,
Transient growth of perturbations in stokes oscillatory flows, Journal of Fluid Mechanics, vol.794, p.4, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01377582
Active control of transition by periodic suction-blowing, Physics of Fluids, vol.27, issue.6, pp.1345-1347, 1958. ,
Parametric testing of chevrons on single flow hot jets, 2004. ,
Intermittent sound generation and its control in a free-shear flow, Physics of Fluids, vol.22, 2010. ,
H 2 optimal actuator and sensor placement in the linearised complex ginzburg-landau system, Journal of Fluid Mechanics, vol.681, pp.241-260, 2011. ,
Linear and nonlinear processes in two-dimensional mixing layer dynamics and sound radiation, Journal of Fluid Mechanics, vol.625, pp.321-351, 2009. ,
Sound generation in a mixing layer, Journal of Fluid Mechanics, vol.330, pp.375-409, 1997. ,
Stability of slowly diverging jet flow, J. Fluid Mech, vol.77, issue.2, pp.387-413, 1976. ,
Should model-based inverse inputs be used as feedforward under plant uncertainty?, IEEE Transactions on Automatic Control, vol.47, issue.11, pp.1865-1871, 2002. ,
Nonlinear inversion-based output tracking, IEEE Transactions on Automatic Control, vol.41, issue.7, pp.930-942, 1996. ,
Energy efficiency and performance limitations of linear adaptive control for transition delay, Journal of Fluid Mechanics, vol.810, pp.60-81, 2017. ,
Adaptive and model-based control theory applied to convectively unstable flows, Applied Mechanics Reviews, vol.66, issue.6, p.801, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01103057
On the role of adaptivity for robust laminar flow control, Journal of Fluid Mechanics, vol.767, p.1, 2015. ,
Feed-forward control of a perturbed backward-facing step flow, Journal of Fluid Mechanics, vol.759, pp.181-196, 2014. ,
Instability wave models for the near-field fluctuations of turbulent jets, Journal of Fluid Mechanics, vol.689, pp.97-128, 2011. ,
Parabolized stability equations, Annual Review of Fluid Mechanics, vol.29, issue.1, pp.245-283, 1997. ,
A physics-based approach to flow control using system identification, Journal of Fluid Mechanics, vol.702, pp.26-58, 2012. ,
Adjoint systems and their role in the receptivity problem for boundary layers, Journal of Fluid Mechanics, vol.292, pp.183-204, 1995. ,
Open shear flow instabilities. Perspectives in fluid dynamics pp, pp.159-229, 2000. ,
Absolute and convective instabilities in free shear layers, Journal of Fluid Mechanics, vol.159, pp.151-168, 1985. ,
Local and global instabilities in spatially developing flows, Annual review of fluid mechanics, vol.22, issue.1, pp.473-537, 1990. ,
An eigensystem realization algorithm for modal parameter identification and model reduction, Journal of Guidance, vol.8, issue.5, pp.620-627, 1985. ,
Physical mechanisms of laminar-boundary-layer transition, Annual review of fluid mechanics, vol.26, issue.1, pp.411-482, 1994. ,
A linear systems approach to flow control, Annu. Rev. Fluid Mech, vol.39, pp.383-417, 2007. ,
Jet-noise control by fluidic injection from a rotating plug: linear and nonlinear sound-source mechanisms, Journal of Fluid Mechanics, vol.788, pp.358-380, 2016. ,
Spatial stability characteristics of non-circular jets, 21st AIAA/CEAS Aeroacoustics Conference, p.2537, 2015. ,
Jet-noise reduction: the effect of azimuthal actuation modes, 22nd AIAA/CEAS Aeroacoustics Conference, p.2868, 2016. ,
Exponential vs algebraic growth and, Turbulence and Combustion, vol.70, issue.1-4, pp.183-210, 2003. ,
On the nature of pse approximation, Theoretical and Computational Fluid Dynamics, vol.8, issue.4, pp.253-273, 1996. ,
Active control of boundary-layer instabilities, Journal of Fluid Mechanics, vol.550, pp.185-205, 2006. ,
Survey on jet instability theory, Progress in Aerospace Sciences, vol.21, pp.159-199, 1984. ,
Direct computation of the sound generated by vortex pairing in an axisymmetric jet, Journal of Fluid Mechanics, vol.383, pp.113-142, 1999. ,
, Modern control engineering, vol.4, 2002.
Numerical recipes 3rd edition: The art of scientific computing, 2007. ,
Real-time modelling of wavepackets in turbulent jets, Journal of Fluid Mechanics, vol.821, pp.458-481, 2017. ,
Linear control of oscillator and amplifier flows, Physical Review Fluids, vol.1, issue.4, p.501, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01444167
Riccati-less approach for optimal control and estimation: an application to two-dimensional boundary layers, Journal of Fluid Mechanics, vol.731, pp.394-417, 2013. ,
Parabolized stability analysis of dual-stream jets, 22nd AIAA/CEAS Aeroacoustics Conference, p.3057, 2016. ,
Closed-loop control of fluid flow: a review of linear approaches and tools for the stabilization of transitional flows, AerospaceLab, issue.6, p.1, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-01184632
Harmonic and subharmonic waves during boundary-layer transition, Bull. Amer. Phys. Soc, vol.26, p.1252, 1981. ,
The control of boundary-layer transition using a wave-superposition principle, Journal of Fluid Mechanics, vol.137, pp.233-250, 1983. ,
Three-dimensional vortex analysis and aeroacoustic source characterization of jet core breakdown, Physics of Fluids, vol.25, issue.1, p.112, 1994. ,
A noise controlled free shear flow, Journal of Fluid Mechanics, vol.546, pp.123-152, 2006. ,
Application of variable leading-edge roughness for transition control on swept wings, AIAA paper, vol.283, 2000. ,
