Quadrotor trajectory tracking by using fixed-time differentiator - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Control Année : 2019
Bai-Hui Du
  • Fonction : Auteur
Gang Zheng
Quan Quan
  • Fonction : Auteur
This paper proposes a xed-time differentiator running in parallel with a feedback linearization-based controller, which allows quadrotors to track a given trajectory. The xed-time differentiator estimates outputs' derivatives in a prede ned conver- gence time, largely compensating for initial condition problems and solving the delay problem. Combined with a state reconstruction step, a whole observer-estimator- controller scheme for trajectory tracking problem of quadrotors can be constructed. Also, an LMI optimization-based algorithm to tune parameters of the differentiator is also developed here. The high performance of the proposed model is illustrated by simulation results.
Automatique
IJC_201712.pdf (1.93 Mo) Télécharger le fichier
hal-01947365 , version 1 (06-12-2018)
Bai-Hui Du, Andrey Polyakov, Gang Zheng, Quan Quan. Quadrotor trajectory tracking by using fixed-time differentiator. International Journal of Control, 2019, 2019 - Issue 12, ⟨10.1080/00207179.2018.1462534⟩. ⟨hal-01947365⟩
68 Consultations
432 Téléchargements
