A stochastic flow approach to model the mean velocity profile of wall-bounded flows - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Physical Review E Année : 2019
There is no satisfactory model to explain the mean velocity profile of the whole turbulent layer in canonical wall-bounded flows. In this paper, a mean velocity profile expression is proposed for wall-bounded turbulent flows based on a recently proposed stochastic representation of fluid flows dynamics. This original approach, called modeling under location uncertainty introduces in a rigorous way a subgrid term generalizing the eddy-viscosity assumption and an eddy-induced advection term resulting from turbulence inhomogeneity. This latter term gives rise to a theoreti- cally well-grounded model for the transitional zone between the viscous sublayer and the turbulent sublayer. An expression of the small-scale velocity component is also provided in the viscous zone. Numerical assessments of the results are provided for turbulent boundary layer flows, pipe flows and channel flows at various Reynolds numbers.
PRE-revised final.pdf (1.06 Mo) Télécharger le fichier
hal-01947662 , version 1 (07-12-2018)
hal-01947662 , version 2 (21-12-2018)
hal-01947662 , version 3 (20-05-2019)
hal-01947662 , version 4 (21-05-2019)
  • HAL Id : hal-01947662 , version 3
Benoît Pinier, Etienne Mémin, Sylvain Laizet, Roger Lewandowski. A stochastic flow approach to model the mean velocity profile of wall-bounded flows. Physical Review E , In press. ⟨hal-01947662v3⟩
479 Consultations
527 Téléchargements
