, MONU-005 (COMODO). C. Eldred was funded by the ANR through contract
Lemarié acknowledges the support of the French LEFE program through project CHRONOS ,
Implicit free-surface method for the bryan-cox-semtner ocean model, Journal of Geophysical Research: Oceans, vol.99, issue.C4, pp.7991-8014, 1994. ,
The development of a free-surface bryan-300 cox-semtner ocean model, Journal of Physical Oceanography, vol.21, issue.9, pp.1333-1348, 1991. ,
, , 1991.
The regional oceanic modeling system (roms): a split-explicit, free-surface, topography-following-coordinate oceanic model, Ocean Modelling, vol.9, issue.4, pp.347-404, 2005. ,
Computational kernel algorithms for fine-scale, multiprocess, longtime oceanic simulations, Handbook of Numerical Analysis, vol.14, pp.121-183, 2009. ,
Time splitting and linear stability of the slow part of the barotropic component, Ocean Modelling, vol.23, issue.3-4, pp.73-81, 2008. ,
On simulating flows with multiple time scales using a method of averages, Theoretical and Computational Fluid Dynamics, vol.9, issue.3-4, pp.281-292, 1997. ,
Stable split time stepping schemes for large-scale ocean modeling, Journal of Computational Physics, vol.135, issue.1, pp.54-65, 1997. ,
Barotropic-baroclinic time splitting for ocean circulation modeling, Journal of Computational Physics, vol.135, issue.1, pp.30-53, 1997. ,
On the time-splitting scheme used in the princeton ocean model, Journal of Computational Physics, vol.228, issue.8, pp.2874-2905, 2009. ,
, Fluid Mechanics, 2002.
Revisiting open boundary conditions from the point of view of characteristic variables, Ocean Modelling, vol.9, issue.3, pp.231-252, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00134856
Structure of the barotropic mode in layered ocean models, Ocean Modelling, vol.11, issue.1-2, pp.49-68, 2006. ,
Tracer conservation with an explicit free 340 surface method for z-coordinate ocean models, Monthly Weather Review, vol.129, issue.5, pp.1081-1098, 2001. ,
, , 2001.
Energy conservation issues in sigma-coordinate free-surface ocean models, Ocean Modelling, vol.20, issue.1, pp.61-345, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00518955
Correction and commentary for "ocean forecasting in terrainfollowing coordinates: Formulation and skill assessment of the regional ocean modeling system, Journal of Computational Physics, vol.227, issue.24, pp.8985-9000, 2009. ,
Vertical differencing of the primitive equations based on the charney-phillips grid in hybrid sigma-p vertical coordinates, Monthly weather review, vol.124, issue.3, pp.511-528, 1996. ,
Comparison of lorenz and charney-phillips vertical discretisations for dynamics-boundary layer coupling. part i: Steady states, Quarterly Journal of the Royal Meteorological Society, vol.139, issue.673, pp.1073-1086, 2013. ,
, The resulting algorithm has a slightly enlarged stability range and is less dissipative at the price of a slightly higher phase error
, 16), right, green) is, as expected
, 281105, ? given by (B.4) and ? given by (B.2) is formally first order in time with (as required) second order damping (|?| = 1 ? ?µ 2 + O(µ 4 )) with a range of stability and a phase error closed to the original ROMS scheme
