Tokamesh : A software for mesh generation in Tokamaks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2018
The generation flux aligned mesh for tokamaks is a difficult task that is not easily automated and very often ask for manual intervention and specific expertise. This report presents the work done in the framework workpackage of the WP 5.1 of the EoCoE action to design and build a software for this task.
RR-9230.pdf (5.94 Mo) Télécharger le fichier
hal-01948060 , version 1 (07-12-2018)
  • HAL Id : hal-01948060 , version 1
Herve Guillard, Jalal Lakhlili, Adrien Loseille, Alexis Loyer, Boniface Nkonga, et al.. Tokamesh : A software for mesh generation in Tokamaks. [Research Report] RR-9230, CASTOR. 2018. ⟨hal-01948060⟩
319 Consultations
493 Téléchargements
