Smooth macro-elements based on clough-tocher triangle splits, Numerische Mathematik, vol.90, issue.4, pp.597-616, 2002. ,
Sur l'implementation des éléments finis de hseieh-clough-tocher complet et reduit. HAL, 2006. ,
Development of a fluid code for tokamak edge plasma simulation. Investigation on non-local transport, 2012. ,
Interpolation error estimates for the reduced hsieh-clough-tocher triangle, Math. Comp, vol.32, pp.335-344, 1978. ,
Finite element stiffness matrices for analysis of plates in bending, Int. Conf. on Matrix Methods in Structural Mechanics, pp.515-545, 1965. ,
Bézier surfaces and finite elements for mhd simulations, Journal of Computational Physics, vol.227, issue.16, pp.7423-7445, 2008. ,
A practical guide to splines, 2001. ,
Efit tokamak equilibria with toroidal flow and anisotropic pressure using the two-temperature guiding-centre plasma, Nuclear Fusion, vol.53, issue.11, p.113040, 2013. ,
Mesh Generation, vol.848, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00073738
A new high-order fluid solver for tokamak edge plasma transport simulations based on a magnetic-field independent discretization, Contributions to Plasma Physics, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01657680
ultimate' robustness in meshing an arbitrary polyhedron, International Journal for Numerical Methods in Engineering, vol.58, issue.7, pp.1061-1089, 2003. ,
Back to edge flips in 3 dimensions, International Meshing Roundtable 12, pp.393-402, 2003. ,
Data dependent thin plate energy and its use in interactive surface modeling, Computer Graphics Forum, vol.15, issue.3, pp.175-185, 1996. ,
Interpolating and approximating scattered 3D-data with hierarchical tensor product B-splines, Surface Fitting and Multiresolution Methods, pp.163-172, 1997. ,
Solving Ordinary Differential Equations I. Nonstiff Problems, 1993. ,
Quasi-static free-boundary equilibrium of toroidal plasma with cedres++, Journal of Plasma Physics, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01088772
Fast degree elevation and knot insertion for b-spline curves, Computer Aided Geometric Design, vol.22, issue.2, pp.183-197, 2005. ,
A triangular finite element with first-derivative continuity applied to fusion mhd applications, Journal of Computational Physics, vol.200, issue.1, pp.133-152, 2004. ,
, , 1963.
The NURBS Book, 1995. ,
, Spline Functions on Triangulations, 2007.
DOI : 10.1017/cbo9780511721588
Chapter 10-unstructured mesh generation and adaptation, Handbook of Numerical Methods for Hyperbolic Problems, vol.18, pp.263-302, 2017. ,
Structural classification and stability of divergence-free vector field, Physica D: Nonlinear Phenomena, pp.107-126, 2002. ,
Carre: a quasi-orthogonal mesh generator for 2d edge plasma modelling, Computer Physics Communications, pp.232-246, 1996. ,
The Calculus of Variations in the Large, 1934. ,
Computing intersections of planar spline curves using knot insertion, Computer Aided Geometric Design, vol.26, issue.3, pp.351-366, 2009. ,
A concept for parametric surface fitting which avoids the parametrization problem, Computer Aided Geometric Design, vol.20, issue.6, pp.343-362, 2003. ,
Sur les points singuliers d'une forme de pfaff complètement intégrable ou d'une fonction numérique, C. R. Acad. Sci, pp.847-849, 1946. ,
The eirene and b2-eirene codes, Fusion Science and Technology, pp.172-186, 2005. ,
Plasma equilibrium in a magnetic field, Reviews of Plasma Physics, 1966. ,
Algorithms for extracting correct critical points and constructing topological graphs from discrete geographical elevation data, Computer Graphics Forum, 1995. ,
Tetgen, a delaunay-based quality tetrahedral mesh generator, ACM Trans. Math. Softw, vol.41, issue.2, p.36, 2015. ,
Nonlinear magnetohydrodynamics with high-order finite elements, J. Comp. Phys, vol.195, p.355, 2004. ,
Mesh generation for confined fusion plasma simulation, Eng. with Comput, vol.32, issue.2, pp.285-293, 2016. ,
