Scheduling parallel tasks-algorithms and complexity, Handbook of Scheduling, 2004. ,
StarPU: a unified platform for task scheduling on heterogeneous multicore architectures, Concurrency and Computation: Practice and Experience, vol.23, issue.2, pp.187-198, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00384363
, KAAPI: A thread scheduling runtime system for data flow computations on cluster of multi-processors, in: International Workshop on Parallel Symbolic Computation, pp.15-23, 2007.
Hierarchical taskbased programming with StarSs, IJHPCA, vol.23, issue.3, pp.284-299, 2009. ,
DOI : 10.1177/1094342009106195
PaRSEC: Exploiting heterogeneity for enhancing scalability, Computing in Science & Engineering, vol.15, issue.6, pp.36-45, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00930217
Scheduling data-intensiveworkflows onto storage-constrained distributed resources, CCGrid'07, pp.401-409, 2007. ,
Robust memory-aware mappings for parallel multifrontal factorizations, SIAM J. Scientific Computing, vol.38, issue.3 ,
URL : https://hal.archives-ouvertes.fr/hal-01334113
Bounded memory scheduling of dynamic task graphs, Proc. of PACT, pp.343-356, 2014. ,
Parallel scheduling of dags under memory constraints, 2018 IEEE International Parallel and Distributed Processing Symposium (IPDPS), pp.204-213, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01828312
The generation of optimal code for arithmetic expressions, Journal of the ACM, vol.17, issue.4, pp.715-728, 1970. ,
Complete register allocation problems, STOC'73, pp.182-195, 1973. ,
The pebbling problem is complete in polynomial space, SIAM J. Comput, vol.9, issue.3 ,
An application of generalized tree pebbling to sparse matrix factorization, SIAM J. Alg. Discrete Methods, vol.8, issue.3, pp.375-395, 1987. ,
Memory-optimal evaluation of expression trees involving large objects, Computer Languages, Systems & Structures, vol.37, issue.2, pp.63-75, 2011. ,
Parallel scheduling of task trees with limited memory, ACM Transactions on Parallel Computing, vol.2, issue.2, p.13, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01070356
Scheduling data-intensive workflows on storage constrained resources, Proc. of the 4th Workshop on Workflows in Support of Large-Scale Science (WORKS'09, 2009. ,
Controlling the memory subscription of distributed applications with a task-based runtime system, Proc. of IPDPS Workshops, pp.318-327, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01284004
, Concurrent collections, Scientific Programming, vol.18, issue.3-4, pp.203-217, 2010.
Register Pressure in Instruction Level Parallelism, Theses, Université de Versailles-Saint Quentin en Yvelines, 2002. ,
On optimal tree traversals for sparse matrix factorization, Proc. of the Int. Par. & Dist. Processing Symposium (IPDPS), pp.556-567, 2011. ,
URL : https://hal.archives-ouvertes.fr/ensl-00527462
Complete register allocation problems, SIAM journal on Computing, vol.4, issue.3, pp.226-248, 1975. ,
, Combinatorial optimization: networks and matroids, Courier Corporation, 2001.
, Reducibility among combinatorial problems, pp.85-103, 1972.
Some simplified np-complete graph problems, Theoretical Computer Science, vol.1, issue.3, pp.237-267, 1976. ,
On the algorithmic effectiveness of digraph decompositions and complexity measures, Discrete Optimization, vol.8, issue.1, pp.129-138, 2011. ,
Minimum s-t cut in weighted directed acyclic graphs with possibly negative weights ,
, , 2009.
Sequential and parallel algorithms for minimum flows, Journal of Applied Mathematics and Computing, vol.15, issue.1, pp.53-75, 2004. ,
, A new approach to the maximum flow problem, pp.136-146, 1986.
Register saturation in instruction level parallelism, International Journal of Parallel Programming, vol.33, issue.4, pp.393-449, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-00130633
Computers and Intractability, a Guide to the Theory of NP-Completeness, 1979. ,
The igraph software package for complex network research, InterJournal Complex Systems, p.1695, 2006. ,
Daggen: A synthetic task graph generator ,
One step toward bridging the gap between theory and practice in moldable task scheduling with precedence constraints, Concurrency and Computation: Practice and Experience, vol.27, pp.1010-1026, 2015. ,
A bi-criteria algorithm for scheduling parallel task graphs on clusters, pp.243-252, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00533904
, Community resources for enabling research in distributed scientific workflows, vol.1, pp.177-184, 2014.
Performance-effective and lowcomplexity task scheduling for heterogeneous computing, IEEE Trans. Parallel Distributed Systems, vol.13, issue.3, pp.260-274, 2002. ,
