Ledger Design Language: Designing and Deploying Formally Verified Public Ledgers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Cryptocurrencies have popularized public ledgers, known colloquially as "blockchains". While the Bitcoin blockchain is relatively simple to reason about as, effectively, a hash chain, more complex public ledgers are largely designed without any formalization of desired cryptographic properties such as authentication or integrity. These designs are then implemented without assurances against real-world bugs leading to little assurance with regards to practical, real-world security. Ledger Design Language (LDL) is a modeling language for describing public ledgers. The LDL compiler produces two outputs. The first output is a an applied-pi calculus symbolic model representing the public ledger as a protocol. Using ProVerif, the protocol can be played against an active attacker, whereupon we can query for block integrity, authenticity and other properties. The second output is a formally verified read/write API for interacting with the public ledger in the real world, written in the F ⋆ programming language. F ⋆ features such as dependent types allow us to validate a block on the public ledger, for example, by type-checking it so that its signing public key be a point on a curve. Using LDL's outputs, public ledger designers obtain automated assurances on the theoretical coherence and the real-world security of their designs with a single framework based on a single modeling language .
ldl_short.pdf (139.33 Ko) Télécharger le fichier
hal-01948971 , version 1 (09-12-2018)
  • HAL Id : hal-01948971 , version 1
Nadim Kobeissi, Natalia Kulatova. Ledger Design Language: Designing and Deploying Formally Verified Public Ledgers. Workshop on Security Protocol Implementations: Development and Analysis, Apr 2018, London, United Kingdom. ⟨hal-01948971⟩
Collections
INRIA INRIA2
48 Consultations
140 Téléchargements
