A Unifying Framework for Homogeneous Model Composition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Software and Systems Modeling Année : 2019
The growing use of models for separating concerns in complex systems has lead to a proliferation of model composition operators. These composition operators have traditionally been defined from scratch following various approaches differing in formality, level of detail, chosen paradigm, and styles. Due to the lack of proper foundations for defining model composition (concepts, abstractions, or frameworks), it is difficult to compare or reuse composition operators. In this paper , we stipulate the existence of a unifying framework that reduces all structural composition operators to structural merging, and all composition operators acting on discrete behaviors to event scheduling. We provide convincing evidence of this hypothesis by discussing how structural and behavioral homogeneous model composition operators (i.e., weavers) can be mapped onto this framework. Based on this discussion, we propose a conceptual model of the framework, and identify a set of research challenges, which, if addressed, lead to the realization of this framework to support rigorous and efficient engineering of model composition operators for homogeneous and eventually heterogeneous modeling languages.
sosym-unifiedcompositionframework.pdf (1.13 Mo) Télécharger le fichier
hal-01949050 , version 1 (09-12-2018)
Jörg Kienzle, Gunter Mussbacher, Benoit Combemale, Julien Deantoni. A Unifying Framework for Homogeneous Model Composition. Software and Systems Modeling, 2019, pp.1-19. ⟨10.1007/s10270-018-00707-8⟩. ⟨hal-01949050⟩
347 Consultations
359 Téléchargements
