Uncertainty analysis framework for trust based routing in manet, vol.10, pp.1101-1111, 2017. ,
The impacts of network size on the performance of routing protocols in mobile ad-hoc networks, Circuits, Communications and System (PACCS), 2010 Second PacificAsia Conference on, vol.1, pp.18-22, 2010. ,
Trust computations and trust dynamics in mobile adhoc networks: A survey, IEEE Communications Surveys & Tutorials, vol.14, issue.2, pp.279-298, 2012. ,
Dealing with uncertainty: A survey of theories and practices, IEEE Transactions on Knowledge and Data Engineering, vol.25, issue.11, pp.2463-2482, 2013. ,
Fuzzy uncertainty analysis in system modelling, Computer Aided Chemical Engineering, vol.20, pp.391-396, 2005. ,
Modeling uncertainty in risk assessment: an integrated approach with fuzzy set theory and monte carlo simulation, Accident Analysis & Prevention, vol.55, pp.242-255, 2013. ,
Hermes: A quantitative trust establishment framework for reliable data packet delivery in manets, Journal of Computer Security, vol.15, issue.1, pp.3-38, 2007. ,
The eigentrust algorithm for reputation management in p2p networks, Proceedings of the 12th international conference on World Wide Web, pp.640-651, 2003. ,
Mobility reduces uncertainty in manets, INFOCOM 2007. 26th IEEE International conference on computer communications, pp.1946-1954, 2007. ,
, Uncertainty modeling and reduction in manets, IEEE transactions on mobile computing, vol.10, issue.7, pp.1035-1048, 2010.
Interference prediction in mobile ad hoc networks with a general mobility model, IEEE Transactions on Wireless Communications, vol.14, issue.8, pp.4277-4290, 2015. ,
Node failure effect on reliability of mobile ad-hoc networks, Communication Systems and Network Technologies (CSNT), pp.207-211, 2014. ,
Security enhancements for mobile ad hoc networks with trust management using uncertain reasoning, IEEE Transactions on Vehicular Technology, vol.63, issue.9, pp.4647-4658, 2014. ,
Bayesian and belief-functions formalisms for evidential reasoning: a conceptual analysis, Readings in uncertain reasoning, pp.540-574, 1990. ,
An evidential model of distributed reputation management, Proceedings of the first international joint conference on Autonomous Agents and Multiagent Systems: Part 1, pp.294-301, 2002. ,
Regression-based trust model for mobile ad hoc networks, IET Information Security, vol.6, issue.3, pp.131-140, 2012. ,
Impact of trust model on on-demand multi-path routing in mobile ad hoc networks, Computer Communications, vol.36, issue.9, pp.1078-1093, 2013. ,
Trust-based routing mechanism in manet: Design and implementation, Mobile Networks and Applications, vol.18, issue.5, pp.666-677, 2013. ,
Mobility and its impact on performance of aodv and dsr in mobile ad hoc network, 2012 Third Asian Himalayas International Conference on, pp.1-5, 2012. ,
Impact of node density and mobility on the performance of aodv and dsr in manets, Communication Systems Networks and Digital Signal Processing (CSNDSP), 2010 7th International Symposium on, pp.61-65, 2010. ,
Opportunistic routing in presence of selfish nodes for manet, Wireless Personal Communications, vol.82, issue.2, pp.689-708, 2015. ,
Quantifying trust in mobile ad-hoc networks, Integration of Knowledge Intensive Multi-Agent Systems, pp.65-70, 2005. ,
Impact of node speed and transmission range on the hello interval of manet routing protocols, Information and Communication Technology Convergence (ICTC), 2016 International Conference on, pp.634-636, 2016. ,
