On the convergence of stochastic forward-backward-forward algorithms with variance reduction in pseudo-monotone variational inequalities - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
We develop a new stochastic algorithm with variance reduction for solving pseudo-monotone stochastic variational inequalities. Our method builds on Tseng's forward-backward-forward algorithm, which is known in the deterministic literature to be a valuable alternative to Korpelevich's extragradient method when solving variational inequalities over a convex and closed set governed with pseudo-monotone and Lipschitz continuous operators. The main computational advantage of Tseng's algorithm is that it relies only on a single projection step, and two independent queries of a stochastic oracle. Our algorithm incorporates a variance reduction mechanism, and leads to a.s. convergence to solutions of a merely pseudo-monotone stochastic variational inequality problem. To the best of our knowledge, this is the first stochastic algorithm achieving this by using only a single projection at each iteration.
FBF_NIPS2018.pdf (258.48 Ko) Télécharger le fichier
hal-01949361 , version 1 (10-12-2018)
  • HAL Id : hal-01949361 , version 1
Radu Bot, Panayotis Mertikopoulos, Mathias Staudigl, Phan Tu Vuong. On the convergence of stochastic forward-backward-forward algorithms with variance reduction in pseudo-monotone variational inequalities. NIPS 2018 - Workshop on Smooth Games, Optimization and Machine Learning, Dec 2018, Montréal, Canada. pp.1-5. ⟨hal-01949361⟩
99 Consultations
156 Téléchargements
