France Life Imaging (FLI)-Information Analysis and Management (IAM) Provider of data storage and processing solutions for preclinical imaging studies
Animal population imaging is a domain still in its infancy that requires a similar technical support as for human population imaging: technical solutions for storing and processing large volumes of data in a distributed scientific work environment. This challenge has been identified by the national French action FLI-IAM (https://portal.fli-iam.irisa.fr). IAM (Information Analysis and Management) is the computation science node of France Life Imaging (FLI). It provides access to multiple imaging databases and computation resources and takes care of the interoperability between databases 1 and processing pipelines (local or cluster-based platforms). The preclinical work group within FLI-IAM has especially worked on a solution for hosting preclinical imaging studies, that is called Shanoir 2 Small Animal.
