Skew Cyclic Codes, AAECC (Applied Algebra in Engineering, Communication and Computing), vol.18, pp.379-389, 2007. ,
Coding with skew polynomial rings, Journal of Symbolic Computation, vol.44, pp.1644-1656, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00454884
Fast multiplication for skew polynomials, p.2017 ,
URL : https://hal.archives-ouvertes.fr/hal-01457808
Bilinear Forms over a Finite Field with Applications to Coding Theory, J. Combin. Theory, vol.25, pp.226-241, 1978. ,
Skew and linearized Reed-Solomon codes and maximum sum rank distance codes over any division ring, J. Algebra, vol.504, pp.587-612, 2018. ,
Reliable and Secure Multishot Network Coding using Linearized Reed-Solomon Codes ,
Theory of codes with maximum rank distance, Problemy Peredachi Informatsii, vol.21, issue.1, pp.3-16, 1985. ,
A New Algorithm for Decoding Reed-Solomon Codes, Communications, Information and Network Security, pp.55-68 ,
A subresultant theory for Ore polynomials and applications, proceedings ISSAC, 1998. ,
, Theory of non-commutative polynomials, vol.34, pp.480-508, 1933.
Sub-quadratic decoding of Gabidulin codes, IEEE Int. Symp. Inf. Theory (ISIT, 2016. ,
Codes de Gabidulin en caractéristique nulle : application au codage espace-temps, 2015. ,
Maximum-Rank Array Codes and their Application to Crisscross Error Correction, IEEE Trans. Inform. Theory, 1991. ,
Decoding of block and convolutional codes in rank metric, 2013. ,
URL : https://hal.archives-ouvertes.fr/tel-01056746
