, If new law is created then add to use. ? If new local politics then add to use. ? If business is new then add to taxes. ? If knowledge is new then knowledge add to Area-1 or Area-2. ? If matter is incomplete then matter is back to citizen. ? If matter is Division-1 then use Procedure-1 or Pro-cedure-2. 2. Example KnowledgeDelete ? If matter has status=TRUE then matter move to archives. ? If knowledge is outdated then knowledge delete from actual knowledge. ? If citizen it has taken care of all matter then citizen delete from ontology. ? If procedure unresolved then procedure delete from ontology, rules: 1. Example KnowledgeInsert ? If citizen is new then add to citizen. ? If business is new then add to business. ?
, Cross-cultural Knowledge Management, vol.13, 2009.
, The New Science of Cities, 2013.
, Essentials of Knowledge Management, 2003.
, , 2009.
, Creation of the Urban Knowledge Portal: E-learning and Knowledge Inventor Context, 2015.
Knowledge Management Toolkit ,
Smart Cities: Big Data, Civic Hackers, and the Quest for a New Utopia, 2014. ,
