Dirichlet process mixtures under affine transformations of the data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computational Statistics Année : 2021
Location-scale Dirichlet process mixtures of Gaussians (DPM-G) have proved extremely useful in dealing with density estimation and clustering problems in a wide range of domains. Motivated by an astronomical application, in this work we address the robustness of DPM-G models to affine transformations of the data, a natural requirement for any sensible statistical method for density estimation. First, we devise a coherent prior specification of the model which makes posterior inference invariant with respect to affine transformation of the data. Second, we formalise the notion of asymptotic robustness under data transformation and show that mild assumptions on the true data generating process are sufficient to ensure that DPM-G models feature such a property. Our investigation is supported by an extensive simulation study and illustrated by the analysis of an astronomical dataset consisting of physical measurements of stars in the field of the globular cluster NGC 2419.
ArXiv_v2_preview.pdf (1.44 Mo) Télécharger le fichier
hal-01950652 , version 1 (11-12-2018)
hal-01950652 , version 2 (06-01-2020)
Julyan Arbel, Riccardo Corradin, Bernardo Nipoti. Dirichlet process mixtures under affine transformations of the data. Computational Statistics, 2021, 36, pp.577-601. ⟨10.1007/s00180-020-01013-y⟩. ⟨hal-01950652v2⟩
113 Consultations
119 Téléchargements
