Superedge grouping for object localization by combining appearance and shape informations, CVPR, 2012. ,
Free-shape polygonal object localization, ECCV, 2014. ,
Efficient multi-view reconstruction of large-scale scenes using interest points, delaunay triangulation and graph cut, ICCV, 2007. ,
DOI : 10.1109/iccv.2007.4408892
URL : http://www.di.ens.fr/~labatut/papers/iccv2007-efficient-multiview.pdf
Scalable surface reconstruction from point clouds with extreme scale and density diversity, CVPR, 2017. ,
DOI : 10.1109/cvpr.2017.268
URL : http://arxiv.org/pdf/1705.00949
Stochastic annealing for nearest-neighbour point processes with application to object recognition, Advances in Applied Probability, vol.26, issue.2, 1994. ,
, CGAL User and Reference Manual, 4, vol.11, 2017.
Stochastic geometry for image analysis, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00793677
An Introduction to the Theory of Point Processes, 1988. ,
Stochastic geometry models in highlevel vision, Journal of Applied Statistics, vol.20, issue.5-6, 1993. ,
DOI : 10.1080/02664769300000065
URL : https://ir.cwi.nl/pub/10408/10408D.pdf
Building outline extraction from digital elevation models using marked point processes, IJCV, vol.72, issue.2, 2007. ,
DOI : 10.1007/s11263-005-5033-7
Recovering line-networks in images by junction-point processes, CVPR, 2013. ,
DOI : 10.1109/cvpr.2013.247
URL : https://hal.archives-ouvertes.fr/hal-00814262
Reversible jump markov chain monte carlo computation and bayesian model determination, Biometrika, vol.82, issue.4, 1995. ,
DOI : 10.2307/2337340
Optimum monte carlo sampling using markov chains, Biometrika, vol.60, 1973. ,
DOI : 10.2307/2335011
, Facts, Conjectures, and Improvements for Simulated Annealing. SIAM Monographs on Mathematical Modeling and Computation, 2002.
DOI : 10.1137/1.9780898718300
Marked point processes for crowd counting, CVPR, 2009. ,
DOI : 10.1109/cvprw.2009.5206621
A 3-D marked point process model for multiview people detection, CVPR, 2011. ,
DOI : 10.1109/cvpr.2011.5995699
URL : http://web.eee.sztaki.hu/%7Eucu/utasiCVPR11.pdf
Geometric feature extraction by a multi-marked point process, vol.32, 2010. ,
DOI : 10.1109/tpami.2009.152
URL : https://hal.archives-ouvertes.fr/inria-00503140
Point processes for unsupervised line network extraction in remote sensing, vol.27, 2005. ,
DOI : 10.1109/tpami.2005.206
URL : http://www-sop.inria.fr/ariana/personnel/Xavier.Descombes/publis_dr/PAMI1.pdf
Marked point process for vascular tree extraction on angiogram, 2007. ,
DOI : 10.1007/978-3-540-74198-5_36
Object point processes for image segmentation, ICPR, 2002. ,
DOI : 10.1109/icpr.2002.1048453
Nearest-neighbour markov point processes and random sets, International Statistical Review, vol.57, issue.2, 1989. ,
DOI : 10.2307/1403381
Spatial delaunay gibbs point processes, Communications in Statistics. Stochastic Models, vol.15, issue.2, 1999. ,
DOI : 10.1080/15326349908807533
A higher-order crf model for road network extraction, CVPR, 2013. ,
Semantic segmentation for line drawing vectorization using neural networks, Computer Graphics Forum, vol.37, issue.2, 2018. ,
Reconstructing loopy curvilinear structures using integer programming, CVPR, 2013. ,
An optimal transport approach to robust reconstruction and simplification of 2d shapes, Computer Graphics Forum, vol.30, issue.5, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00758019
Topology-driven vectorization of clean line drawings, ACM Trans. on Graphics, vol.32, issue.1, 2013. ,
Simplicity: a Global Approach to Line Drawing Vectorization, ACM Trans. on Graphics (Proc. of Siggraph), vol.35, issue.4, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01309271
Enhancing road maps by parsing aerial images around the world, ICCV, 2015. ,
Detecting parametric objects in large scenes by Monte Carlo sampling, IJCV, vol.106, issue.1, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00843022
A database of human segmented natural images and its application to evaluating segmentation algorithms and measuring ecological statistics, ICCV, 2001. ,
Crisp boundary detection using pointwise mutual information, ECCV, 2014. ,
A fast algorithm for multilevel thresholding, Journal of Information Science and Engineering, vol.17, 2001. ,
Optimal contour closure by superpixel grouping, ECCV, 2010. ,
Image partitioning into convex polygons, CVPR, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01140320
Superpixels and polygons using simple non-iterative clustering, CVPR, 2017. ,
A non-self-intersection DouglasPeucker algorithm, IEEE Symposium on Computer Graphics and Image Processing, 2003. ,
Annotating object instances with a polygon-rnn, CVPR, 2017. ,
Image segmentation by polygonal markov fields, Annals of the Institute of Statistical Mathematics, vol.59, issue.3, 2007. ,
Scale-invariant contour completion using conditional random fields, ICCV, 2005. ,
Grabcut-interactive foreground extraction using iterated graph cuts, ACM Trans. on Graphics (Proc. of Siggraph), vol.23, issue.3, 2004. ,
An experimental comparison of mincut/max-flow algorithms for energy minimization in vision, PAMI, vol.26, issue.9, 2004. ,
Deep contrast learning for salient object detection, CVPR, 2016. ,
A Wavelet Tour of Signal Processing, The Sparse Way, 2008. ,
Adaptive image approximation by linear splines over locally optimal delaunay triangulations, Signal Processing Letters, vol.13, issue.5, 2006. ,
Image compression by linear splines over adaptive triangulations, Signal Processing, vol.86, issue.7, 2006. ,
Image compression with anisotropic geodesic triangulations, ICCV, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00366933
A subdivision-based representation for vector image editing, Trans. on Visualization and Computer Graphics, vol.18, issue.11, 2012. ,
Artistic low poly rendering for images, The Visual Computer, vol.32, issue.4, 2016. ,
Efficient point process inference for large-scale object detection, CVPR, 2016. ,
