New interface
Conference papers
HDG Method for the 3d Frequency-Domain Maxwell's Equations With Application to Nanophotonics
Mostafa Javadzadeh Moghtader 1 Stéphane Lanteri 1 Alexis Gobé 1 Liang Li 1
1 NACHOS - Numerical modeling and high performance computing for evolution problems in complex domains and heterogeneous media
CRISAM - Inria Sophia Antipolis - Méditerranée , JAD - Laboratoire Jean Alexandre Dieudonné : UMR6621
Abstract : HDG method is a new class of DG family with significantly less globally coupled unknowns, and can leverage a post-processing step to gain super-convergence. Its features make HDG a possible candidate for computational electromagnetics applications, especially in the frequency-domain. The HDG method introduces an hybrid variable, which represents an additional unknown on each face of the mesh, and leads to a sparse linear system in terms of the degrees of freedom of the hybrid variable only. In [1], we have introduced such a HDG method for the system of 3d time-harmonic Maxwell's, combined to an iterative Schwarz domain decomposition (DD) algorithm to allow for an efficient parallel hybrid iterative-direct solver. The resulting DD-HDG solver has been applied to classical applications of electromagnetics in the microwave regime. Recently, this HDG method has been extended to the solution of the 2d frequency-domain Maxwell's equation coupled to different models of physical (local and non-local) dispersion in metals with application to nanoplasmonics[2]. In the present contribution , we further focus on this particular physical context and propose a arbitrary high order HDG method for solving the system of 3d frequency-domain Maxwell equations coupled to a generalized model of physical dispersion in metallic nanostructures at optical frequencies. Such a generalized dispersion model unifies most common dispersion models, like Drude and Drude-Lorentz models, and it permits to fit large range of experimental data. The resulting DD-HDG solver is capable of using different element types and orders of approximation, hence enabling the possibilities of p-adaptivity and non-conforming meshing, and proves to have interesting potentials for modeling of complex nanophotonic and nanoplasmonic problems.
Complete list of metadata
Cited literature [2 references]  Display  Hide  Download
https://hal.inria.fr/hal-01951465
Contributor : Mostafa Javadzadeh Moghtader Connect in order to contact the contributor
Submitted on : Tuesday, December 11, 2018 - 4:22:55 PM
Last modification on : Thursday, August 4, 2022 - 4:53:26 PM
Identifiers
  • HAL Id : hal-01951465, version 1
Citation
Mostafa Javadzadeh Moghtader, Stéphane Lanteri, Alexis Gobé, Liang Li. HDG Method for the 3d Frequency-Domain Maxwell's Equations With Application to Nanophotonics. 6th European Seminar on Computing, Jun 2018, Pilsen, Czech Republic. ⟨hal-01951465⟩
Share
Metrics
Record views
181
Files downloads
47
