Real solving for positive dimensional systems, Journal of Symbolic Computation, vol.34, issue.6, pp.543-560, 2002. ,
URL : https://hal.archives-ouvertes.fr/inria-00100982
Structural stability and equivalence of linear 2D discrete systems, Proceedings of the IFAC Joint Symposium SSSC & TDS, 2016. ,
Asymptotic and structural stability for a linear 2d discrete roesser model, 10th International Workshop on Multidimensional (nD) Systems (nDS), pp.1-6, 2017. ,
LMI stability conditions for 2D roesser models, IEEE Transactions on Automatic Control, vol.61, issue.3, pp.766-770, 2016. ,
Polar varieties and efficient real elimination, Mathematische Zeitschrift, vol.238, issue.1, pp.115-144, 2001. ,
Generalized polar varieties: Geometry and algorithms, Journal of complexity, vol.21, issue.4, pp.377-412, 2005. ,
Algorithms in Real Algebraic Geometry, Algorithms and Computation in Mathematics, vol.10, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-01083587
Zero location with respect to the unit circle of discrete-time linear system polynomials, Proceedings of the IEEE, vol.72, issue.9, pp.1131-1142, 1984. ,
A circular stability test for general polynomials, Systems & control letters, vol.7, issue.2, pp.89-97, 1986. ,
An immittance-type stability test for 2-d digital filters, Conference Record of the Twenty-Eighth Asilomar Conference on Signals, Systems and Computers, vol.2, pp.918-922, 1994. ,
Zero location of polynomials with respect to the unit-circle unhampered by nonessential singularities. Circuits and Systems I: Fundamental Theory and Applications, IEEE Transactions on, vol.49, issue.3, pp.305-314, 2002. ,
Testing stability of 2-D discrete systems by a set of real 1-D stability tests, IEEE Transactions on Circuits and Systems I: Regular Papers, vol.51, issue.7, pp.1312-1320, 2004. ,
Solving bivariate algebraic systems and topology of plane curves, 2014. ,
URL : https://hal.archives-ouvertes.fr/tel-00979707
Résolution de systmes bivariés et topologie de courbes planes, 2014. ,
Solving bivariate systems: Efficient randomized algorithm for computing rational univariate representations and application to the topology of plane curves, 2013. ,
Separating linear forms and rational univariate representations of bivariate systems, Journal of Symbolic Computation, vol.68, pp.84-119, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-00977671
Quantifier elimination for real closed fields by cylindrical algebraic decomposition, Lecture Notes in Computer Science, vol.33, pp.515-532, 1975. ,
, Varieties, and Algorithms. Undergraduate Texts in Mathematics, 2007.
On the computation of the topology of a non-reduced implicit space curve, ISSAC'08: Proceedings of the twentyfirst international symposium on Symbolic and Algebraic Computation, pp.47-54, 2008. ,
, Multivariable Nyquist theory. International Journal of Control, vol.25, issue.5, pp.657-675, 1977.
Stability test of multidimensional discrete-time systems via sum-ofsquares decomposition, IEEE Transactions on Circuits and Systems I: Regular Papers, vol.53, issue.4, pp.928-936, 2006. ,
LMI stability tests for the Fornasini-Marchesini model, IEEE Transactions on Signal Processing, vol.56, issue.8, pp.4091-4095, 2008. ,
A new efficient algorithm for computing Gröbner bases (F 4 ), J. of Pure and Applied Algebra, vol.139, issue.1-3, pp.61-88, 1999. ,
Author's reply to a counterexample to generalized eigenvalue-based stability tests for 2-d linear systems: Necessary and sufficient conditions, Automatica, vol.46, issue.1, pp.236-237, 2010. ,
A Gröbner free alternative for solving polynomial systems, Journal of Complexity, vol.17, issue.1, pp.154-211, 2001. ,
On two-dimensional filter stability test, IEEE Transactions on Circuits and Systems II: Analog and Digital Signal Processing, vol.41, pp.457-462, 1994. ,
Theory and Application of the z-Transform Method, vol.3, 1964. ,
Solving parametric polynomial systems, Journal of Symbolic Computation, vol.42, pp.636-667, 2007. ,
URL : https://hal.archives-ouvertes.fr/inria-00070678
Stability and stabilisation of linear multidimensional discrete systems in the frequency domain, International Journal of Control, vol.86, issue.11, pp.1969-1989, 2013. ,
The geometry of the zeros of a polynomial in the complex plane, In Amer. Math. Soc, 1949. ,
Motivations for an arbitrary precision interval arithmetic and the mpfi library, Reliable Computing, vol.11, pp.1-16, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00100985
Solving zero-dimensional systems through the rational univariate representation, Journal of Applicable Algebra in Engineering, Communication and Computing, vol.9, issue.5, pp.433-461, 1999. ,
URL : https://hal.archives-ouvertes.fr/inria-00073264
RS3: Real roots isolation for bivariate algebraic systems of equations with rational coefficients with a finite number of complex roots, 2012. ,
Efficient isolation of polynomial real roots, J. of Computational and Applied Mathematics, vol.162, issue.1, pp.33-50, 2003. ,
URL : https://hal.archives-ouvertes.fr/inria-00072518
Finding at least one point in each connected component of a real algebraic set defined by a single equation, Journal of Complexity, vol.16, issue.4, pp.716-750, 2000. ,
URL : https://hal.archives-ouvertes.fr/inria-00107845
RAGLIB: A library for real solving polynomial systems of equations and inequalities, 2007. ,
Polar varieties and computation of one point in each connected component of a smooth real algebraic set, Proceedings of ISSAC 2003, pp.365-374, 1954. ,
URL : https://hal.archives-ouvertes.fr/inria-00099649
Multidimensional systems: Bibo stability test based on functional schur coefficients, IEEE Transactions on, vol.55, issue.11, pp.5277-5285, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00181756
Tests of stability of multidimensional filters, IEEE Transactions on Circuits and Systems, vol.24, pp.432-437, 1977. ,
Further improvements on Bose's 2-D stability test, International Journal of Control Automation and Systems, vol.2, pp.319-332, 2004. ,
