Monoparametric Tiling of Polyhedral Programs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2018
Tuilage monoparamétré de programmes polyédriques
Tiling is a crucial program transformation, adjusting the ops-to-bytes balance of codes to improve locality. Like parallelism, it can be applied at multiple levels. Allowing tile sizes to be symbolic parameters at compile time has many benefits, including ecient autotuning, and run-time adaptability to system variations. For polyhedral programs, parametric tiling in its full generality is known to be non-linear, breaking the mathematical closure properties of the polyhedral model. Most compilation tools therefore either perform fixed size tiling, or apply parametric tiling in only the final, code generation step. We introduce monoparametric tiling, a restricted parametric tiling transformation. We show that, despite being parametric, it retains the closure properties of the polyhedral model. We first prove that applying monoparametric partitioning (i) to a polyhedron yields a union of polyhedra, and (ii) to an ane function produces a piecewise-ane function. We then use these properties to show how to tile an entire polyhedral program. Our monoparametric tiling is general enough to handle tiles with arbitrary tile shapes that can tesselate the iteration space (e.g., hexagonal, trapezoidal, etc). This enables a wide range of polyhedral analyses and transformations to be applied.
RR-9233.pdf (628.11 Ko) Télécharger le fichier
hal-01952593 , version 1 (12-12-2018)
  • HAL Id : hal-01952593 , version 1
Guillaume Iooss, Christophe Alias, Sanjay Rajopadhye. Monoparametric Tiling of Polyhedral Programs. [Research Report] RR-9233, INRIA Grenoble - Rhone-Alpes. 2018, pp.1-28. ⟨hal-01952593⟩
113 Consultations
264 Téléchargements
