A global sensitivity analysis approach for marine biogeochemical modeling
Clémentine Prieur 1, 2 Laurence Viry 1 Eric Blayo 1 Jean-Michel Brankart 3
1 AIRSEA - Mathematics and computing applied to oceanic and atmospheric flows
Grenoble INP - Institut polytechnique de Grenoble - Grenoble Institute of Technology, UGA - Université Grenoble Alpes, LJK - Laboratoire Jean Kuntzmann, Inria Grenoble - Rhône-Alpes
Abstract : This paper introduces the Sobol' indices approach for global sensitivity analysis, in the context of marine biogeochemistry. Such an approach is particularly well suited for ocean biogeochemical models, which make use of numerous parameters within large sets of differential equations with complex dependencies. This sensitivity analysis allows for a detailed study of the relative influence of a large number of input parameters on output quantities of interest to be chosen. It is able to distinguish between direct effects of these parameters and effects due to interaction between two or more parameters. Although demanding in terms of computation, such a tool is now becoming affordable, thanks to the development of distributed computing environments. An applicative example is presented with the Modecogel bio-geochemical model.
Complete list of metadatas
Cited literature [31 references]  Display  Hide  Download
https://hal.inria.fr/hal-01952797
Contributor : Eric Blayo <>
Submitted on : Wednesday, December 12, 2018 - 1:56:36 PM
Last modification on : Wednesday, November 6, 2019 - 8:25:43 AM
Long-term archiving on: Wednesday, March 13, 2019 - 1:47:56 PM
File
Paper-Modecogel.pdf
Identifiers
  • HAL Id : hal-01952797, version 1
Collections
Citation
Clémentine Prieur, Laurence Viry, Eric Blayo, Jean-Michel Brankart. A global sensitivity analysis approach for marine biogeochemical modeling. 2018. ⟨hal-01952797⟩
Share
Metrics
Record views
207
Files downloads
163
