Sensitivity measures, ANOVA-like techniques and the use of bootstrap, Journal of Statistical Computation and Simulation, vol.58, issue.2, pp.99-120, 1997. ,
Investigation and sensitivity analysis of a mechanistic phytoplankton model implemented in a new modular numerical tool (eco3m) dedicated to biogeochemical modelling, Progress in Oceanography, vol.71, issue.1, pp.34-58, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-00746680
Sensitivity of a pelagic ecosystem model to variations of process parameters within a realistic range, Journal of Marine Systems, vol.19, issue.1-3, pp.1-26, 1999. ,
The jackknife estimate of variance, The Annals of Statistics, vol.9, issue.3, pp.586-596, 1981. ,
Can biogeochemical fluxes be recovered from nitrate and chlorophyll data? a case study assimilating data in the northwestern Mediterranean sea at the JGOFS-DYFAMED station, Journal of Marine Systems, vol.40, pp.99-125, 2003. ,
URL : https://hal.archives-ouvertes.fr/hal-00230148
Testing a marine ecosystem model: sensitivity analysis and parameter optimization, Journal of Marine Systems, vol.28, issue.1-2, pp.45-63, 2001. ,
Statistical inference for Sobol pick freeze Monte Carlo method, Statistics, vol.50, issue.4, pp.881-902, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-00804668
Making best use of permutations to compute sensitivity indices with replicated designs, 2017. ,
A class of statistics with asymptotically normal distributions, Annals of Mathematical Statistics, vol.19, pp.293-325, 1948. ,
Importance measures in global sensitivity analysis of nonlinear models, Reliability Engineering & System Safety, vol.52, issue.1, pp.1-17, 1996. ,
Asymptotic normality and efficiency of two Sobol index estimators, ESAIM: Probability and Statistics, vol.18, pp.342-364, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00665048
On latin and hyper-graeco-latin cubes and hyper-cubes, Current Science, vol.11, issue.3, pp.98-99, 1942. ,
Sensitivity analysis of simple global marine biogeochemical models, Global Biogeochemical Cycles, vol.26, issue.2, 2012. ,
Simulation de l'´ ecosystème pélagique de la mer Ligurè a l'aide d'un modèle unidimensionnel. Etude du bilan dematì ere et de la variabilité saisonnì ere, interannuelle et spatiale, 1998. ,
Revisited ecosystem model (MODECOGeL) of the Ligurian sea: seasonal and interannual variability due to atmospheric forcing, J. Marine Syst, vol.37, issue.4, pp.229-258, 2002. ,
Influence of meteorological variability on primary production dynamics in the Ligurian Sea (NW Mediterranean sea) with a 1D hydrodynamic/biological model, J. Marine Syst, vol.16, issue.1-2, pp.23-50, 1998. ,
Monte Carlo and quasi-Monte Carlo sampling, 2009. ,
Comparison of some efficient methods to evaluate the main effect of computer model factors, Journal of Statistical Computation and Simulation, vol.78, issue.2, pp.167-178, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-01093033
Uncertainty and sensitivity analysis for crop models, Working with Dynamic Crop Models: Evaluation, Analysis, Parameterization, and Applications, vol.4, pp.55-99, 2006. ,
Perspectives in three-dimensional modelling of the marine system, ThreeDimensional Models of Marine and Estuarine Dynamics, pp.1-34, 1987. ,
Biogeochemical model of lake Zürich: sensitivity, identifiability and uncertainty analysis, Ecological Modelling, vol.141, issue.1-3, pp.105-123, 2001. ,
Orthogonal arrays for computer experiments, integration and visualization, Statistica Sinica, pp.439-452, 1992. ,
Sensitivity: Global Sensitivity Analysis of Model Outputs, 2017. ,
Making best use of model evaluations to compute sensitivity indices, Computer Physics Communications, vol.145, issue.2, pp.280-297, 2002. ,
, Sensitivity analysis. Wiley Series in Probability and Statistics, 2000.
URL : https://hal.archives-ouvertes.fr/inria-00386559
Reviews and syntheses: parameter identification in marine planktonic ecosystem modelling, Biogeosciences (BG), vol.14, issue.6, pp.1647-1701, 2017. ,
Sensitivity analysis of an ocean carbon cycle model in the north Atlantic: an investigation of parameters affecting the air-sea CO2 flux, primary production and export of detritus, Ocean Science, vol.7, issue.3, pp.405-419, 2011. ,
Sensitivity analysis for nonlinear mathematical models, Mathematical Modeling and Computational Experiment, vol.1, pp.407-414, 1993. ,
A randomized orthogonal array-based procedure for the estimation of first-and second-order Sobol' indices, Journal of Statistical Computation and Simulation, vol.85, issue.7, pp.1358-1381, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-00743964
Assimilation of seasonal chlorophyll and nutrient data into an adjoint three-dimensional ocean carbon cycle model: sensitivity analysis and ecosystem parameter optimization, Global biogeochemical cycles, vol.21, issue.1, 2007. ,
A course in probability, 2006. ,
