, Table B.8, this corresponds to all fluxes to bacteria
, Parameters govern the growth rate, pp.23-24
, ? Decomposition of particulate organic matter (orange)
8, this corresponds to all fluxes from particulate organic matter 666 (C 11 or C 12 ) to dissolved organic nitrogen (C 10 ). Parameters are de-667 composition rates, pp.69-70 ,
, In Table B.8, this corresponds to the flux 669 from ammonium (C 2 ) to nitrate (C 1 ). The parameter is the nitrification 670 rate
Sensitivity measures, ANOVA-like tech-676 niques and the use of bootstrap, Journal of Statistical Computation, p.677 ,
, Simulation, vol.58, issue.2, pp.99-120, 1997.
Investigation and 679 sensitivity analysis of a mechanistic phytoplankton model implemented 680 in a new modular numerical tool (eco3m) dedicated to biogeochemical 681 modelling, Progress in Oceanography, vol.71, issue.1, pp.34-58, 2006. ,
A statistical overview and perspectives 683 on data assimilation for marine biogeochemical models, Environmetrics, vol.684, issue.4, pp.203-213, 2014. ,
Sensitivity of a pelagic ecosystem model to 686 variations of process parameters within a realistic range, Journal of Marine 687 Systems, vol.19, issue.1-3, pp.1-26, 1999. ,
The jackknife estimate of variance. The Annals of 689 ,
, Statistics, vol.9, issue.3, pp.586-596, 1981.
, Can biogeochemical fluxes be recovered from nitrate and chlorophyll data? 692 a case study assimilating data in the northwestern Mediterranean sea at 693 the JGOFS-DYFAMED station, Journal of Marine Systems, vol.40, pp.99-125, 2003.
Testing a marine ecosystem 696 model: sensitivity analysis and parameter optimization, Journal of Marine 697 Systems, vol.28, issue.1-2, pp.45-63, 2001. ,
Statistical 699 inference for Sobol pick freeze Monte Carlo method, Statistics, vol.50, issue.4, pp.881-700, 2016. ,
Making best use of permuta-702 tions to compute sensitivity indices with replicated designs, 2017. ,
A class of statistics with asymptotically normal distribu-705 tions, Annals of Mathematical Statistics, vol.19, pp.293-325, 1948. ,
Importance measures in global sensitivity analysis 707 of nonlinear models, Reliability Engineering & System Safety, vol.52, issue.1, pp.1-17, 1996. ,
Asymptotic 710 normality and efficiency of two Sobol index estimators, ESAIM: Probability 711 and Statistics, vol.18, pp.342-364, 2014. ,
On latin and hyper-graeco-latin cubes and hyper-cubes, Current 713 Science, vol.11, issue.3, pp.98-99, 1942. ,
Sensitivity analysis of simple global 715 marine biogeochemical models, Global Biogeochemical Cycles, vol.26, issue.2, 2012. ,
Simulation de l'écosystème pélagique de la mer Ligureà, p.717 ,
, Etude du bilan de matière et de la variabilité 718
, , 1998.
Revisited ecosystem model (MODECOGeL) of ,
, the Ligurian sea: seasonal and interannual variability due to atmospheric 722 forcing, J. Marine Syst, vol.37, issue.4, pp.229-258, 2002.
Influence of meteorological variability on primary 724 production dynamics in the Ligurian Sea (NW Mediterranean sea) with a 725 1D hydrodynamic/biological model, J. Marine Syst, vol.16, issue.1-2, pp.23-50, 1998. ,
Monte Carlo and quasi-Monte Carlo sampling, 2009. ,
Comparison of some efficient methods to 729 evaluate the main effect of computer model factors, Journal of Statistical 730 Computation and Simulation, vol.78, issue.2, pp.167-178, 2008. ,
Hydrological changes in the ligurian sea (nw 732 mediterranean, dyfamed site) during 19952007 and biogeochemical conse-733 quences, Biogeosciences, vol.7, issue.7, pp.2117-2128, 2010. ,
Uncertainty and sensitivity analysis 735 for crop models, p.736 ,
, Working with Dynamic Crop Models: Evaluation, Analysis, Parameteri-737 zation, and Applications, vol.4, pp.55-99, 2006.
Global sensitivity 739 analysis of an end-to-end marine ecosystem model of the north sea: Factors 740 affecting the biomass of fish and benthos, Ecological Modelling, vol.273, pp.251-741, 2014. ,
Factorial sampling plans for preliminary computational exper-743 iments, Technometrics, vol.33, issue.2, pp.161-174, 1991. ,
Perspectives in three-dimensional modelling 745 of the marine system, p.746 ,
, Dimensional Models of Marine and Estuarine Dynamics, pp.1-34, 1987.
Biogeochemical model of lake Zürich: 749 sensitivity, identifiability and uncertainty analysis, Ecological Modelling, pp.105-123, 2001. ,
On the use of data assimilation in biogeochemical modelling, 752 Ocean Weather Forecasting, pp.525-547, 2006. ,
Orthogonal arrays for computer experiments, integration and 754 visualization, Statistica Sinica, pp.439-452, 1992. ,
, , p.756
Sensitivity: Global Sen-757 sitivity Analysis of Model Outputs, 2017. ,
Making best use of model evaluations to compute sensitivity 759 indices, Computer Physics Communications, vol.145, issue.2, pp.280-297, 2002. ,
, Sensitivity analysis. Wiley Series in 761 Probability and Statistics, 2000.
URL : https://hal.archives-ouvertes.fr/inria-00386559
, , p.763
Sensitivity of the simulated oxygen minimum zone to bio-764 geochemical processes at an oligotrophic site in the arabian sea, Ecological, vol.765, pp.12-23, 2018. ,
, , p.767
Reviews and syntheses: parameter 768 identification in marine planktonic ecosystem modelling, Biogeosciences, vol.769, issue.6, pp.1647-1701, 2017. ,
Sensitivity analysis of an ocean carbon 771 cycle model in the north Atlantic: an investigation of parameters affecting 772 the air-sea CO2 flux, primary production and export of detritus, Science, vol.773, issue.3, pp.405-419, 2011. ,
Sensitivity analysis for nonlinear mathematical models, Mathemat-775 ical Modeling and Computational Experiment, vol.1, pp.407-414, 1993. ,
A randomized orthogonal array-based procedure 777 for the estimation of first-and second-order Sobol' indices, Journal, p.778 ,
, Statistical Computation and Simulation, vol.85, issue.7, pp.1358-1381, 2015.
Assimilation of seasonal chloro-780 phyll and nutrient data into an adjoint three-dimensional ocean carbon 781 cycle model: sensitivity analysis and ecosystem parameter optimization ,
, Global biogeochemical cycles, vol.21, issue.1, 2007.
Time-dependent global sensitivity anal-784 ysis of the c-rive biogeochemical model in contrasted hydrological and 785 trophic contexts, Water research, vol.144, pp.341-355, 2018. ,
A course in probability, vol.787, 2006. ,
