Calibrated Fairness in Bandits - Archive ouverte HAL Access content directly
Preprints, Working Papers, ... Year :
(1) , (1) , (2) , (1) , (1)
1
2
We study fairness within the stochastic, multi-armed bandit (MAB) decision making framework. We adapt the fairness framework of "treating similar individuals similarly" [5] to this seing. Here, an 'individual' corresponds to an arm and two arms are 'similar' if they have a similar quality distribution. First, we adopt a smoothness constraint that if two arms have a similar quality distribution then the probability of selecting each arm should be similar. In addition, we dene the fairness regret, which corresponds to the degree to which an algorithm is not calibrated, where perfect calibration requires that the probability of selecting an arm is equal to the probability with which the arm has the best quality realization. We show that a variation on ompson sampling satises smooth fairness for total variation distance, and give añ O((kT) 2/3) bound on fairness regret. is complements prior work [12], which protects an on-average beer arm from being less favored. We also explain how to extend our algorithm to the dueling bandit seing. ACM Reference format:
1707.01875.pdf (178.64 Ko) Télécharger le fichier
Dates and versions
hal-01953314 , version 1 (12-12-2018)
Identifiers
Cite
Yang Liu, Goran Radanovic, Christos Dimitrakakis, Debmalya Mandal, David C Parkes. Calibrated Fairness in Bandits. 2018. ⟨hal-01953314⟩
146 View
60 Download
Share
