Dispersive and dissipative properties of discontinuous Galerkin finite element methods for the second-order wave equation, Journal of Scientific Computing, vol.27, issue.1, pp.5-40, 2006. ,
Comparison of high order algorithms in Aerosol and Aghora for compressible flows, ESAIM: Proceedings, vol.43, pp.1-16, 2013. ,
A numerical scheme for the compressible low-Mach number regime of ideal fluid dynamics, Journal of Scientific Computing, vol.72, issue.2, pp.623-646, 2017. ,
A discontinuous Galerkin method for inviscid low Mach number flows, J. Comput. Phys, vol.228, issue.11, pp.3996-4011, 2009. ,
Stability of preconditioned finite volume schemes at low Mach numbers, BIT Numerical Mathematics, vol.45, issue.3, pp.463-480, 2005. ,
An entropy satisfying two-speed relaxation system for the barotropic Euler equations. Application to the numerical approximation of low Mach number flows, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01661275
Explicit Runge-Kutta schemes and finite elements with symmetric stabilization for first-order linear PDE systems, SIAM Journal on Numerical Analysis, vol.48, issue.6, pp.2019-2042, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00380659
An all-regime Lagrange-Projection like scheme for the gas dynamics equations on unstructured meshes, Communications in Computational Physics, vol.20, issue.1, pp.188-233, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01007622
Runge-Kutta discontinuous Galerkin methods for convectiondominated problems, Journal of scientific computing, vol.16, issue.3, pp.173-261, 2001. ,
All speed scheme for the low Mach number limit of the isentropic Euler equations, Communications in Computational Physics, vol.10, issue.1, pp.1-31, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00630995
Analysis of Godunov type schemes applied to the compressible Euler system at low Mach number, Journal of Computational Physics, vol.4, issue.229, pp.978-1016, 2010. ,
Construction of modified Godunov type schemes accurate at any Mach number for the compressible Euler system, Mathematical Models and Methods in Applied Sciences, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-00776629
The influence of cell geometry on the Godunov scheme applied to the linear wave equation, Journal of Computational Physics, vol.229, issue.14, pp.5315-5338, 2010. ,
Simulation d'écoulements pariétaux génériques à bas nombre de Mach pour l'amélioration du refroidissement des chambres de combustion aéronautiques, 2015. ,
Study of a new asymptotic preserving scheme for the Euler system in the low Mach number limit, SIAM J. Sci. Comput, vol.39, issue.5, pp.2099-2128, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01297238
A class of implicit upwind schemes for Euler simulations with unstructured meshes, Journal of Computational Physics, vol.84, issue.1, pp.174-206, 1989. ,
URL : https://hal.archives-ouvertes.fr/inria-00076037
Étude de la réponse d'un écoulement avec transfert pariétal de masse à un forçage acoustique: application au refroidissement des chambres de combustion aéronautiques, 2013. ,
Gmsh: A 3-d finite element mesh generator with built-in pre-and post-processing facilities, International journal for numerical methods in engineering, vol.79, issue.11, pp.1309-1331, 2009. ,
Strong stability preserving Runge-Kutta and multistep time discretizations, 2011. ,
On the theory of semi-implicit projection methods for viscous incompressible flow and its implementation via a finite element method that also introduces a nearly consistent mass matrix. part 2: Implementation, International Journal for Numerical Methods in Fluids, vol.11, issue.5, pp.621-659, 1990. ,
On the behavior of upwind schemes in the low Mach number limit. IV: P0 approximation on triangular and tetrahedral cells, Computers & Fluids, vol.38, issue.10, pp.1969-1972, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00072433
On the behaviour of upwind schemes in the low Mach number limit: A review. Handbook of Numerical Analysis, vol.18, pp.203-231, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01534938
On the behaviour of upwind schemes in the low Mach number limit, Computers & Fluids, vol.28, issue.1, pp.63-86, 1999. ,
A Mach-sensitive implicit-explicit scheme adapted to compressible multi-scale flows, Journal of Computational and Applied Mathematics, vol.340, pp.122-150, 2018. ,
DOI : 10.1016/j.cam.2018.02.019
URL : https://hal.archives-ouvertes.fr/hal-01531306
A Mach-sensitive splitting approach for Euler-like systems, ESAIM: Mathematical Modelling and Numerical Analysis, 2018. ,
DOI : 10.1051/m2an/2017063
URL : https://hal.archives-ouvertes.fr/hal-01466827
A conservative isothermal wall boundary condition for the compressible Navier-Stokes equations, Journal of Scientific Computing, vol.30, issue.2, pp.177-192, 2007. ,
DOI : 10.1007/s10915-005-9040-1
5.8 internal incompressible viscous flow. The Handbook of Fluid Dynamics, p.62, 1998. ,
Singular limits of quasilinear hyperbolic systems with large parameters and the incompressible limit of compressible fluids, Communications on pure and applied Mathematics, vol.34, issue.4, pp.481-524, 1981. ,
Low-cost implicit schemes for all-speed flows on unstructured meshes, Internat. J. Numer. Methods Fluids, vol.58, issue.5, pp.493-526, 2008. ,
DOI : 10.1002/fld.1730
URL : https://hal.archives-ouvertes.fr/hal-00357646
Liquid and liquid-gas flows at all speeds, J. Comput. Phys, vol.255, pp.53-82, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00695799
An all-speed Roe-type scheme and its asymptotic analysis of low Mach number behaviour, Journal of Computational Physics, vol.227, issue.10, pp.5144-5159, 2008. ,
DOI : 10.1016/j.jcp.2008.01.037
Mechanism of Roe-type schemes for all-speed flows and its application, Computers & Fluids, vol.86, pp.56-70, 2013. ,
DOI : 10.1016/j.compfluid.2013.07.004
URL : http://arxiv.org/pdf/1107.3744
Development of Roe-type scheme for all-speed flows based on preconditioning method, Computers & Fluids, vol.38, issue.4, pp.810-817, 2009. ,
Inviscid transonic flow over airfoils, AIAA Journal, vol.8, issue.12, pp.2157-2162, 1970. ,
New numerical solver for flows at various Mach numbers, Astronomy & Astrophysics, vol.576, p.50, 2015. ,
DOI : 10.1051/0004-6361/201425059
URL : https://www.aanda.org/articles/aa/pdf/2015/04/aa25059-14.pdf
Godunov-type schemes with an inertia term for unsteady full Mach number range flow calculations, J. Comput. Phys, vol.281, pp.556-590, 2015. ,
DOI : 10.1016/j.jcp.2014.10.041
URL : https://hal.archives-ouvertes.fr/hal-01096422
Low Mach number asymptotics of the Navier-Stokes equations and numerical implications, VKI Lecture Series on Computational fluid dynamics, pp.1-52, 1999. ,
Discontinuous Galerkin solution of preconditioned Euler equations for very low Mach number flows, Internat. J. Numer. Methods Fluids, vol.63, issue.4, pp.449-467, 2010. ,
DOI : 10.1002/fld.2083
A high-order accurate discontinuous Galerkin finite element method for laminar low Mach number flows, Internat. J. Numer. Methods Fluids, vol.72, issue.1, pp.43-68, 2013. ,
DOI : 10.1002/fld.3732
A weakly asymptotic preserving low Mach number scheme for the Euler equations of gas dynamics, SIAM J. Sci. Comput, vol.36, issue.6, pp.989-1024, 2014. ,
L 2 Roe: a low dissipation version of Roe's approximate Riemann solver for low Mach numbers, Internat. J. Numer. Methods Fluids, vol.81, issue.2, pp.71-86, 2016. ,
Centered-potential regularization for the advection upstream splitting method, SIAM J. Numer. Anal, vol.54, issue.5, pp.3083-3104, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01152395
A mixture-energy-consistent six-equation two-phase numerical model for fluids with interfaces, cavitation and evaporation waves, J. Comput. Phys, vol.259, pp.331-357, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01135994
A robust implicit-explicit acoustic-transport splitting scheme for two-phase flows, Journal of Computational Physics, vol.339, pp.328-355, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01448468
A discontinuous Galerkin finite element discretization of the Euler equations for compressible and incompressible fluids, J. Comput. Phys, vol.227, issue.11, pp.5426-5446, 2008. ,
On the dissipation mechanism of upwind-schemes in the low mach number regime: A comparison between Roe and HLL, Journal of Computational Physics, vol.229, issue.2, pp.221-232, 2010. ,
A low-Mach number fix for Roe's approximate Riemann solver, Journal of Computational Physics, vol.230, issue.13, pp.5263-5287, 2011. ,
The influence of cell geometry on the accuracy of upwind schemes in the low Mach number regime, Journal of Computational Physics, vol.228, issue.8, pp.2918-2933, 2009. ,
Fast singular limits of hyperbolic pdes, Journal of differential equations, vol.114, issue.2, pp.476-512, 1994. ,
