Vincent's theorem from a modern point of view. Categorical Studies in Italy, Rendiconti del Circolo Matematico di Palermo, Serie II, issue.64, pp.179-191, 2000. ,
On the complexity of exclusion algorithms for optimization, Journal of Complexity, vol.18, issue.2, pp.573-588, 2002. ,
Error estimates for adaptive finite element computations, SIAM Journal on Numerical Analysis, vol.15, issue.4, pp.736-754, 1978. ,
Meshing of surfaces, Effective Computational Geometry for Curves and Surfaces. Mathematics and Visualization, pp.181-229, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-00488274
Isotopic implicit surface meshing, Discrete & Computational Geometry, vol.1, issue.39, pp.138-157, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00488819
Solving bivariate systems using rational univariate representations, J. Complexity, vol.37, pp.34-75, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01342211
Condition: The geometry of numerical algorithms, vol.349, 2013. ,
Complete subdivision algorithms, II: Isotopic meshing of singular algebraic curves, Journal of Symbolic Computation, vol.47, issue.2, pp.131-152, 2012. ,
Continuous amortization and extensions: With applications to bisection-based root isolation, Journal of Symbolic Computation, vol.77, pp.78-126, 2016. ,
The complexity of an adaptive subdivision method for approximating real curves, Proceedings of the 2017 ACM on International Symposium on Symbolic and Algebraic Computation. ISSAC. ACM, pp.61-68, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01528392
Sqfreeeval: An (almost) optimal real-root isolation algorithm, Journal of Symbolic Computation, vol.47, issue.2, pp.153-166, 2012. ,
Continuous amortization: A non-probabilistic adaptive analysis technique, Electronic Colloquium on Computational Complexity, 2009. ,
Root isolation of zero-dimensional polynomial systems with linear univariate representation, Journal of Symbolic Computation, vol.47, issue.7, pp.843-858, 2012. ,
Certified rational parametric approximation of real algebraic space curves with local generic position method, Journal of Symbolic Computation, vol.58, pp.18-40, 2013. ,
Sampling and meshing a surface with guaranteed topology and geometry, SIAM Journal on Computing, vol.37, issue.4, pp.1199-1227, 2007. ,
Polynomial real root isolation using Descarte's rule of signs, Proceedings of the 3rd ACM International Symposium on Symbolic and Algebraic Computation. ISSAC, pp.272-275, 1976. ,
Computing the real roots of a polynomial by the exclusion algorithm, Numerical Algorithms, vol.4, issue.1, pp.1-24, 1993. ,
Amortized bound for root isolation via Sturm sequences, Symbolic-numeric computation, pp.113-129, 2007. ,
Almost tight recursion tree bounds for the descartes method, Proceedings of the International Symposium on Symbolic and Algebraic Computation. ISSAC, pp.71-78, 2006. ,
Geometric constraint solver using multivariate rational spline functions, Proceedings of the 6th ACM Symposium on Solid Modeling and Applications, pp.1-10, 2001. ,
On location and approximation of clusters of zeros of analytic functions, Foundations of Computational Mathematics, vol.5, issue.3, pp.257-311, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-00186736
Fast generation of molecular surfaces from 3d data fields with an enhanced "marching cube" algorithm, Journal of Computational Chemistry, vol.14, issue.2, pp.246-250, 1993. ,
Methods of search for solving polynomial equations, Journal of the Association for Computing Machinery, vol.17, issue.2, pp.273-283, 1970. ,
Variant quantifier elimination, J. Symb. Comput, vol.47, issue.7, pp.883-901, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00778365
On the minimum of a polynomial function on a basic closed semialgebraic set and applications, SIAM Journal on Optimization, vol.23, issue.1, pp.241-255, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00776280
New bounds for the Descartes method, Journal of Symbolic Computation, vol.41, issue.1, pp.49-66, 2006. ,
Newton-Algorithmen zur Bestimmung von, Nullstellen mit Fehlerschranken. Computing, vol.4, pp.187-201, 1969. ,
Non-local isotopic approximation of nonsingular surfaces, Computer-Aided Design, vol.45, issue.2, pp.451-462, 2013. ,
Marching cubes: A high resolution 3D surface construction algorithm, SIGGRAPH Computer Graphics, vol.21, issue.4, pp.163-169, 1987. ,
On continued fraction expansion of real roots of polynomial systems, complexity and condition numbers, Theoretical Computer Science, vol.412, issue.22, pp.2312-2330, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00530756
Introduction to interval analysis, Society for Industrial and Applied Mathematics, 2009. ,
Subdivision methods for solving polynomial equations, Journal of Symbolic Computation, vol.44, issue.3, pp.292-306, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00070350
Approximating complex polynomial zeros: modified weyl's quadtree construction and improved newton's iteration, Journal of Complexity, vol.16, issue.1, pp.213-264, 2000. ,
Isotopic approximation of implicit curves and surfaces, Proceedings of Eurographics/ACM SIGGRAPH Symposium on Geometry Processing, pp.245-254, 2004. ,
Isotopic meshing of implicit surfaces, The Visual Computer, vol.23, pp.45-58, 2007. ,
Computer methods for the range of functions, Ellis Horwood Series: Mathematics and its Applications, 1984. ,
When newton meets descartes: A simple and fast algorithm to isolate the real roots of a polynomial, Proc. of the 37th International Symposium on Symbolic and Algebraic Computation (ISSAC), pp.297-304, 2012. ,
A simple but exact and efficient algorithm for complex root isolation and its complexity analysis, Proceedings of the 36th International Symposium on Symbolic and Algebraic Computation. ISSAC, pp.353-360, 2011. ,
Subdivision as a fundamental building block of digital geometry processing algorithms, 15th Toyota Conference: Scientific and Engineering Computations for the 21st Century-Methodologies and Applications, pp.207-219, 2002. ,
Isotopic arrangement of simple curves: an exact numerical approach based on subdivision, 2011. ,
Interval analysis for computer graphics, Proceedings of the 19th Annual conference on Computer graphics and interactive techniques, pp.121-130, 1992. ,
Fast algorithms for Taylor shifts and certain difference equations, Proceedings of the 22nd International Symposium on Symbolic and Algebraic Computation. ISSAC. ACM, pp.40-47, 1997. ,
On soft predicates in subdivision motion planning, Computational Geometry. Theory and Applications, vol.48, issue.8, pp.589-605, 2015. ,
On soft predicates in subdivision motion planning, Computational Geometry, vol.48, issue.8, pp.589-605, 2015. ,
Approximating the zeros of analytic functions by the exclusion algorithm, Numerical Algorithms, vol.6, issue.1, pp.63-88, 1994. ,
Numerical analysis of a bisection-exclusion method to find zeros of univeriate analytic functions, Journal of Complexity, vol.21, issue.5, pp.652-690, 2005. ,
Adaptive isotopic approximation of nonsingular curves: the parameterizability and nonlocal isotopy approach, Discrete & Computational Geometry, vol.45, issue.4, pp.760-795, 2011. ,
Analytic root clustering: A complete algorithm using soft zero tests, Conference on Computability in Europe, pp.434-444, 2013. ,
Towards exact numerical voronoi diagrams, Proceedings 9th International Symposium on Voronoi Diagrams in Science and Engineering. ISVD, pp.2-16, 2012. ,
