Abstract : This paper is concerned with a minimax control problem (also known as a robust Markov decision process (MDP) or a game against nature) with general state and action spaces under the discounted cost optimality criterion. We are interested in approximating numerically the value function and an optimal strategy of this general discounted minimax control problem. To this end, we derive structural Lipschitz continuity properties of the solution of this robust MDP by imposing suitable conditions on the model, including Lipschitz continuity of the elements of the model and absolute continuity of the Markov transition kernel with respect to some probability measure μ. Then, we are able to provide an approximating minimax control model with finite state and action spaces, and hence computationally tractable, by combining these structural properties with a suitable discretization procedure of the state space (related to a probabilistic criterion) and the action spaces (associated to a geometric criterion). Finally, it is shown that the corresponding approximation errors for the value function and the optimal strategy can be controlled in terms of the discretization parameters. These results are also extended to a two-player zero-sum Markov game
