Stable screening -Python code, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02129219
Audio inpainting, IEEE Transactions on Audio, Speech and Language Processing, vol.20, issue.3, pp.922-932, 2012. ,
URL : https://hal.archives-ouvertes.fr/inria-00577079
A sparse signal reconstruction perspective for source localization with sensor arrays, IEEE Transactions on Signal Processing, vol.53, issue.8, pp.3010-3022, 2005. ,
Sparse spike deconvolution with minimum scale, Signal Processing with Adaptive Sparse Structured Representations (SPARS workshop), pp.123-126, 2005. ,
Matching pursuits with time-frequency dictionaries, IEEE Transactions on Signal Processing, vol.41, issue.12, pp.3397-3415, 1993. ,
Orthogonal matching pursuit: recursive function approximation with applications to wavelet decomposition, 27th Asilomar Conference on Signals, Systems and Computers, pp.40-44, 1993. ,
Atomic decomposition by basis pursuit, SIAM Journal on Scientific Computing, vol.20, issue.1, pp.33-61, 1998. ,
Regression shrinkage and selection via the lasso, Journal of the Royal Statistical Society. Series B (Methodological), vol.58, issue.1, pp.267-288, 1996. ,
An iterative thresholding algorithm for linear inverse problems with a sparsity constraint, Communications on Pure and Applied Mathematics, vol.57, issue.11, pp.1413-1457, 2004. ,
A fast iterative shrinkage-thresholding algorithm for linear inverse problems, SIAM Journal on Imaging Sciences, vol.2, issue.1, pp.183-202, 2009. ,
A new TwIST: Two-step iterative shrinkage/thresholding algorithms for image restoration, IEEE Transactions on Image Processing, vol.16, issue.12, pp.2992-3004, 2007. ,
Sparse reconstruction by separable approximation, IEEE Transactions on Signal Processing, vol.57, issue.7, pp.2479-2493, 2009. ,
A first-order primal-dual algorithm for convex problems with applications to imaging, Journal of Mathematical Imaging and Vision, vol.40, issue.1, pp.120-145, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00490826
Double sparsity: Learning sparse dictionaries for sparse signal approximation, IEEE Transactions on Signal Processing, vol.58, issue.3, pp.1553-1564, 2010. ,
Toward fast transform learning, International Journal of Computer Vision, vol.114, issue.2, pp.195-216, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01281930
Flexible multilayer sparse approximations of matrices and applications, IEEE Journal of Selected Topics in Signal Processing, vol.10, issue.4, pp.688-700, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01167948
Trainlets: Dictionary learning in high dimensions, IEEE Transactions on Signal Processing, vol.64, issue.12, pp.3180-3193, 2016. ,
Learning dictionaries as a sum of Kronecker products, IEEE Signal Processing Letters, vol.24, issue.5, pp.559-563, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01672349
Safe feature elimination in sparse supervised learning, EECS Department, 2010. ,
Learning sparse representations of high dimensional data on large scale dictionaries, Advances in Neural Information Processing Systems, pp.900-908, 2011. ,
Dynamic screening: Accelerating first-order algorithms for the lasso and grouplasso, IEEE Transactions on Signal Processing, vol.63, issue.19, pp.5121-5132, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01084986
Mind the duality gap: safer rules for the lasso, International Conference on Machine Learning, vol.37, pp.333-342, 2015. ,
Gap safe screening rules for sparsity enforcing penalties, Journal of Machine Learning Research, vol.18, issue.128, pp.1-33, 2017. ,
Screening tests for lasso problems, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.39, issue.5, pp.1008-1027, 2017. ,
Dynamic screening with approximate dictionaries, Colloque GRETSI, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01598021
, Faster and still safe: combining screening techniques and structured dictionaries to accelerate the lasso, IEEE International Conference on Acoustics, Speech and Signal Processing, pp.4069-4073, 2018.
, A Mathematical Introduction to Compressive Sensing, 2013.
Separable dictionary learning, IEEE Conference on Computer Vision and Pattern Recognition, pp.438-445, 2013. ,
Learning fast dictionaries for sparse representations using low-rank tensor decompositions, International Conference on Latent Variable Analysis and Signal Separation, pp.456-466, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01709343
Sure independence screening for ultrahigh dimensional feature space, Journal of the Royal Statistical Society: Series B (Statistical Methodology), vol.70, issue.5, pp.849-911, 2008. ,
Strong rules for discarding predictors in lasso-type problems, Journal of the Royal Statistical Society: Series B (Statistical Methodology), vol.74, issue.2, pp.245-266, 2011. ,
Fast lasso screening tests based on correlations, IEEE International Conference on Acoustics, Speech and Signal Processing, pp.2137-2140, 2012. ,
Lasso screening rules via dual polytope projection, Journal of Machine Learning Research, vol.16, issue.1, pp.1063-1101, 2015. ,
Safe screening tests for lasso based on firmly non-expansiveness, IEEE International Conference on Acoustics, Speech and Signal Processing, pp.4732-4736, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01419314
Safe screening with variational inequalities and its application to lasso, International Conference on Machine Learning, vol.32, pp.289-297, 2014. ,
Fast active-set-type algorithms for l1-regularized linear regression, Proceedings of the Thirteenth International Conference on Artificial Intelligence and Statistics, pp.397-404, 2010. ,
Blitz: A principled meta-algorithm for scaling sparse optimization, International Conference on Machine Learning, pp.1171-1179, 2015. ,
From safe screening rules to working sets for faster lasso-type solvers, NIPS Workshop on Optimization for Machine Learning, 2017. ,
Celer: a fast solver for the lasso with dual extrapolation, International Conference on Machine Learning, pp.3321-3330, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01833398
Joint screening tests for lasso, IEEE International Conference on Acoustic, Speech and Signal Processing, pp.4084-4088, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01739477
On the lasso and its dual, Journal of Computational and Graphical Statistics, vol.9, issue.2, pp.319-337, 2000. ,
Selective minimum-norm solution of the biomagnetic inverse problem, IEEE Transactions on Biomedical Engineering, vol.42, issue.6, pp.608-615, 1995. ,
Mixed-norm estimates for the M/EEG inverse problem using accelerated gradient methods, Physics in Medicine & Biology, vol.57, issue.7, pp.1937-1961, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00690774
MNE software for processing MEG and EEG data, Neuroimage, vol.86, pp.446-460, 2014. ,
ESAIM: Control, Optimisation and Calculus of Variations, vol.19, pp.190-218, 2013. ,
