The Gas Transmission Problem When the Merchant and the Transport Functions Are Disconnected, 2007. ,
MPEC strategies for cost optimization of pipeline operations, Computers & Chemical Engineering, vol.34, issue.6, pp.900-913, 2010. ,
Simulation and Optimization Models of Steady-State Gas Transmission Networks, Energy Procedia. 3rd Trondheim Gas Technology Conference, pp.130-139, 201464-06-05. ,
Non-Linear Network Problems, In: Quarterly of Applied Mathematics, vol.13, pp.431-443, 1956. ,
DOI : 10.1090/qam/77398
Discrete-Variable Extremum Problems, Operations Research, vol.5, pp.266-288, 1957. ,
DOI : 10.1287/opre.5.2.266
The Gas Transmission Problem Solved by an Extension of the Simplex Algorithm, Management Science, vol.46, pp.1454-1465, 2000. ,
Combination of Nonlinear and Linear Optimization of Transient Gas Networks, In: INFORMS Journal of Computing, vol.23, pp.605-617, 2011. ,
Mathematical Optimization for Challenging Network Planning Problems in Unbundled Liberalized Gas Markets, In: Energy Systems, vol.5, pp.449-473, 2014. ,
Chapter 2: Physical and Technical Fundamentals of Gas Networks, Society for Industrial and Applied Mathematics, pp.17-43, 2015. ,
The Reservation-Allocation Network Flow Problem, 2014. ,
Towards Globally Optimal Solutions for MINLPs by Discretization Techniques with Applications in Gas Network Optimization, 2011. ,
In: Evaluating Gas Network Capacities, Society for Industrial and Applied Mathematics, pp.103-122, 2015. ,
A New Algorithm for MINLP Applied to Gas Transport Energy Cost Minimization, pp.321-353, 2013. ,
Solving Highly Detailed Gas Transport MINLPs: Block Separability and Penalty Alternating Direction Methods, In: INFORMS Journal on Computing, vol.30, pp.309-323, 2018. ,
Solving power-constrained gas transportation problems using an MIP-based alternating direction method, Computers & Chemical Engineering, vol.82, pp.303-317, 2015. ,
On the Quantification of Nomination Feasibility in Stationary Gas Networks with Random Load, In: Mathematical Methods of Operations Research, vol.84, issue.2, pp.427-457, 2016. ,
A Multilevel Model of the European Entry-Exit Gas Market, In: Mathematical Methods of Operations Research, 2018. ,
Algorithmic Results for Potential-Based Flows: Easy and Hard Cases, 2018. ,
Challenges in Optimal Control Problems for Gas and Fluid Flow in Networks of Pipes and Canals: From Modeling to Industrial Applications, Industrial Mathematics and Complex Systems: Emerging Mathematical Models, Methods and Algorithms, pp.77-122, 2017. ,
Computing Maximal Entry and Exit Capacities of Transportation Networks-Complexity Analysis and a Discrete Relaxation Applied to Gas Transmission Systems, 2017. ,
The New Entry-Exit Model in the EU and Its Consequences for Gas Supply Companies, pp.477-491, 2009. ,
Knapsack Problems, 2004. ,
Ueber Die Auflösung Der Gleichungen, Auf Welche Man Bei Der Untersuchung Der Linearen Vertheilung Galvanischer Ströme Geführt Wird, Annalen der Physik, vol.148, pp.497-508, 1847. ,
DOI : 10.1002/andp.18471481202
URL : https://zenodo.org/record/2242265/files/article.pdf
Transmission Networks and Electricity Markets, Fundamentals of Power System Economics, pp.141-204, 2005. ,
Evaluating Gas Network Capacities. SIAM, 2015. ,
Hydraulics of Pipeline Systems, 1999. ,
Optimierung Technischer Kapazitäten in Gasnetzen, In: Optimierung in der Energiewirtschaft. VDI-Berichte, pp.105-114, 2011. ,
Mixed Integer Models for the Stationary Case of Gas Network Optimization, Mathematical Programming, vol.105, pp.563-582, 2006. ,
Étude de réseaux de transport et de distribution de fluide, In: RAIRO-Operations Research, vol.11, issue.2, pp.243-248, 1977. ,
, Directive 2003/55/EC of the European Parliament and of the Council of 26 June 2003 concerning common rules for the internal market in natural gas and repealing Directive, pp.57-78
, Directive 2009/73/EC of the European Parliament and of the Council concerning common rules for the internal market in natural gas and repealing Directive, pp.36-54
, Directive 98/30/EC of the European Parliament and of the Council of 22
, concerning common rules for the internal market in natural gas, OJ L, vol.204, pp.1-12, 1998.
Optimization Problems in Natural Gas Transportation Systems: A State-of-the-Art Review, In: Applied Energy, vol.147, pp.536-555 ,
Preprocessing on Natural Gas Transmission Networks, 2000. ,
A Reduction Technique for Natural Gas Transmission Network Optimization Problems, In: Annals of Operations Research, vol.117, issue.1-4, pp.217-234, 2002. ,
Robust Optimal Discrete Arc Sizing for Tree-Shaped Potential Networks, 2018. ,
Computational Optimization of Gas Compressor Stations: MINLP Models versus Continuous Reformulations, In: Mathematical Methods of Operations Research, vol.83, issue.3, pp.409-444, 2016. ,
The Impact of Potential-Based Physics Models on Pricing in Energy Networks, 2018. ,
Structural Properties of Feasible Bookings in the European Entry-Exit Gas Market System, 2018. ,
A Generic Interior-Point Framework for Nonsmooth and Complementarity Constrained Nonlinear Optimization, 2013. ,
A Primal Heuristic for Nonsmooth Mixed Integer Nonlinear Optimization ,
, , pp.295-320, 2013.
In: Evaluating Gas Network Capacities, SIAM-MOS series on Optimization. SIAM, 2015. Chap. 9, pp.163-180 ,
In: Evaluating Gas Network Capacities, pp.181-210, 2015. ,
High Detail Stationary Optimization Models for Gas Networks, In: Optimization and Engineering, vol.16, issue.1, pp.131-164, 2015. ,
High Detail Stationary Optimization Models for Gas Networks: Validation and Results, In: Optimization and Engineering, vol.17, pp.437-472, 2016. ,
DOI : 10.1007/s11081-015-9300-3
Validation of Nominations in Gas Networks and Properties of Technical Capacities, 2014. ,
, , p.1
mail address: martine.labbe@ulb.ac.be E-mail address: frank.plein@ulb ,
Energie Campus Nürnberg, Fürther Str. 250, 90429 Nürnberg, Germany E-mail address: martin.schmidt@uni-trier, vol.4 ,
