Semantic Array Dataflow Analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2018
This paper revisits the polyhedral model’s key analysis, dependency analysis. The semantic formulation we propose allows a new definition of the notion of dependency and the computation of the dependency set. We argue that this new formalization will later allow for a new vision of the polyhedral model in terms of semantics, which will help us fully characterize its expressivity and applicability. We also believe that abstract semantics will be the key for designing an approximate abstract model in order to enhance the applicability of the polyhedral model.
Dans ce rapport de recherche nous réexprimons un des calculs-clefs du modèle polyédrique: le calcul des dépendances, en termes d’opérations sur une sémantique concrète impérative des programmes.
RR-9232.pdf (663.77 Ko) Télécharger le fichier
hal-01954396 , version 1 (13-12-2018)
  • HAL Id : hal-01954396 , version 1
Paul Iannetta, Laure Gonnord, Lionel Morel, Tomofumi Yuki. Semantic Array Dataflow Analysis. [Research Report] RR-9232, Inria Grenoble Rhône-Alpes. 2018, pp.1-22. ⟨hal-01954396⟩
371 Consultations
315 Téléchargements
