Probabilistic Event Graph to Model Safety and Security for Diagnosis Purposes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Edwin Bourget
Simon Foley
  • Fonction : Auteur
Youssef Laarouchi
  • Fonction : Auteur
Diagnosing accidental and malicious events in an industrial control system requires an event model with specific capacities. Most models are dedicated to either safety or security but rarely both. And the latter are developed for objectives other than diagnosis and therefore unfit for this task. In this paper, we propose an event model considering both safety and security events, usable in real-time, with a probabilistic measure of on-going and future events. This model is able to replace alerts in the context of more global scenarios, including with reinforcements or conflicts between safety and security. The model is then used to provide an analysis of some of the security and safety events in the Taum Sauk Hydroelectric Power Station.
470961_1_En_3_Chapter.pdf (271.3 Ko) Télécharger le fichier
hal-01954422 , version 1 (13-12-2018)
hal-01954422 , version 2 (06-03-2019)
Paternité
Edwin Bourget, Frédéric Cuppens, Nora Cuppens-Bouhlahia, Samuel Dubus, Simon Foley, et al.. Probabilistic Event Graph to Model Safety and Security for Diagnosis Purposes. 32th IFIP Annual Conference on Data and Applications Security and Privacy (DBSec), Jul 2018, Bergamo, Italy. pp.38-47, ⟨10.1007/978-3-319-95729-6_3⟩. ⟨hal-01954422v1⟩
108 Consultations
53 Téléchargements
