A Lumped Parameter Model to Study Atrioventricular Valve Regurgitation in Stage 1 and Changes Across Stage 2 Surgery in Single Ventricle Patients - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Biomedical Engineering Année : 2018
Goal: This manuscript evaluates atrioventric-ular valve regurgitation (AVVR) in babies born with an already very challenging heart condition, i.e., with single ven-tricle physiology. Although the second surgery that single ventricle patients undergo is thought to decrease AVVR, there is much controversy in the clinical literature about AVVR treatment. Methods: The effect of AVVR on Stage 1 haemodynamics and resulting acute changes from conversion to Stage 2 circulation in single ventricle patients are analyzed through lumped parameter models. Several degrees of AVVR severity are analyzed, for two types of valve regurgitation: incomplete leaflet closure and valve pro-lapse. Results: The models show that increasing AVVR in Stage 1 induces the following effects: first, higher stroke volume and associated decrease in ventricular end-systolic volume; second, increase in atrial volumes with V-loop enlargement in pressure-volume curves; third, pulmonary ve-nous hypertension. The Stage 2 surgery results in volume unloading of the ventricle, thereby, driving a decrease in AVVR. However, this effect is offset by an increase in ven-tricular pressures resulting in a net increase in regurgitation fraction (RF) of approximately 0.1 (for example, in severe AVVR, the preoperative RF increases from ∼60% to ∼70% postoperatively). Moreover, despite some improvements to sarcomere function early after Stage 2 surgery, it may deteriorate in cases of severe AVVR. Conclusion: In patients with moderate to severe AVVR, restoration of atrioventric-ular valve competence prior to, or at the time of, Stage 2
PantEtAl_AVVR_TBME2018.pdf (988.37 Ko) Télécharger le fichier
hal-01954784 , version 1 (13-12-2018)
Sanjay Pant, Chiara Corsini, Catriona Baker, Tain-Yen Hsia, Giancarlo Pennati, et al.. A Lumped Parameter Model to Study Atrioventricular Valve Regurgitation in Stage 1 and Changes Across Stage 2 Surgery in Single Ventricle Patients. IEEE Transactions on Biomedical Engineering, 2018, 65 (11), pp.2450-2458. ⟨10.1109/tbme.2018.2797999⟩. ⟨hal-01954784⟩
126 Consultations
258 Téléchargements
