Influence of bidirectional cavopulmonary anastomosis and concomitant valve repair on atrioventricular valve annulus and function, Ann. Thoracic Surg, vol.98, issue.2, pp.641-647, 2014. ,
Risk factor analysis for second-stage palliation of single ventricle anatomy, Ann. Thoracic Surg, vol.93, issue.2, pp.614-619, 2012. ,
Atrioventricular valve regurgitation in patients with single ventricle: Impact of the bidirectional cavopulmonary anastomosis, Ann. Thoracic Surg, vol.72, issue.3, pp.831-835, 2001. ,
Atrioventricular valve repair in patients with functional single-ventricle physiology: Impact of ventricular and valve function and morphology on survival and reintervention, J. Thoracic Cardiovascular Sur, vol.142, issue.2, pp.326-335, 2011. ,
Early surgical correction of atrioventricular valvular regurgitation in single-ventricle patients, Ann. Thoracic Surg, vol.90, issue.4, pp.1320-1323, 2010. ,
Effect of superior cavopulmonary anastomosis on the rate of tricuspid annulus dilation in hypoplastic left heart syndrome, Amer. J. Cardiol, vol.89, issue.1, pp.96-98, 2002. ,
Review of zero-d and 1-d models of blood flow in the cardiovascular system, Biomed. Eng. Online, vol.10, issue.1, 2011. ,
Data assimilation and modelling of patient-specific singleventricle physiology with and without valve regurgitation, J. Biomech, vol.49, issue.11, pp.2162-2173, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01240146
Relation between left ventricular cavity pressure and volume and systolic fiber stress and strain in the wall, Biophys. J, vol.59, issue.1, pp.93-102, 1991. ,
Dependence of intramyocardial pressure and coronary flow on ventricular loading and contractility: A model study, Ann. Biomed. Eng, vol.34, issue.12, pp.1833-1845, 2006. ,
Inverse problems in reduced order models of cardiovascular haemodynamics: aspects of data assimilation and heart rate variability, J. Roy. Soc. Interface, vol.14, issue.126, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01413446
A clinical appraisal of left atrial function, Eur. Heart J, vol.22, issue.1, pp.22-36, 2001. ,
Mechanical function of the left atriumnew insights based on analysis of pressure-volume relations and doppler echocardiography, Anesthesiology, vol.98, issue.4, pp.975-994, 2003. ,
Right atrial pressure-volume relationships in tricuspid regurgitation, Circulation, vol.73, issue.4, pp.799-808, 1986. ,
Titin-actin interaction: Pevk-actin-based viscosity in a large animal, BioMed Res. Int, p.310791, 2011. ,
The passive properties of muscle fibers are velocity dependent, J. Biomech, vol.47, issue.3, pp.687-693, 2014. ,
Left ventricular response to mitral regurgitation, Circulation, vol.118, issue.22, pp.2298-2303, 2008. ,
Effects of standard mitral valve replacement on left ventricular function, Ann. Thoracic Surg, vol.49, issue.6, pp.866-874, 1990. ,
Real-time left ventricular pressure: Volume loops during percutaneous mitral valve repair with the mitraclip system, Circulation, vol.5, pp.1018-1027, 2013. ,
Left ventricular performance in mitral regurgitation assessed with systolic time intervals and echocardiography, Amer. J. Cardiol, vol.38, issue.7, pp.831-835, 1976. ,
Quantitation of mitral regurgitation using the systolic/diastolic pulmonary venous flow velocity ratio, J. Amer. Coll. Cardiol, vol.31, issue.6, pp.1383-1390, 1998. ,
